• Page 1 of 1
amichon
PARA / WCCOA_315_P003 unable to create DP with master DP
Postby amichon »
I get the following error when i create a DP after creating the master datapoint.
The Dptype contains only one node and the master datapoint contains only the Archive Power Config (with or without PowerConfig the problem is the same)
WCCOAui (1), 2017.07.10 15:16:34.240, CTRL, SEVERE, 5/ctrl, Location of the following log entry:
Module: Para_1
Panel: C:\\Siemens\\Automation\\WinCC_OA\\3.15\\panels\\para.pnl []
Object: 10 named: "activeX" of type: DP_TREE
Script: OnRButtonClk
Library: C:\\Siemens\\Automation\\WinCC_OA\\3.15\\scripts\\libs\\mp.ctl
Line: 340
When creating multiple datapoints the first instance is never created but the following are corrects (ex: TEST_xxx with xxx in the range 1 to 10, only 2 to 10 are created)
I reproduce the bug on different computers with WCCOA 315P3. I haven't WCCOA 315 before P3, but it works very well with WCCOA 314 P5.
