It appears to me that the Plantmodel Editor does not refresh its contents when changes are made.
Here are two examples:
1/ In Editor mode, if I do "Create View" to make a new view for the project, then it does not appear in the tree until I either apply and then remove a filter to the tree, or restart the Plantmodel Editor completely.
2/ In the OPC mode, if I select a node whose access rights are set to "Inherit from parent node" in which case the check boxes for Read, Write, etc. are disabled. If I change the rights to "Apply only for this node", then the check boxes should get disabled right away, but they don't. After I restart the Plantmodel Editor completely they are enabled and I can edit them.
I noticed this with WinCC OA V3.14 P8, and so I copied the panels from V3.15 basic release into my project, but no change there either.
I find this behavior quite annoying when editing and I can't imagine that it is intended to work that way.
Has this been improved in the meantime or are there any plans to do so in the future?
Plantmodel Editor panel doesn\'t refresh after making changes
- RudiKreiner
- kilianvp
Re: Plantmodel Editor panel doesn\'t refresh after making changes
for a older project i created a plant model via script and that worked very well. No restart or filtering was needed
- RudiKreiner
We have 2 users here working on different projects that both have this problem.
If you cannot reproduce it what could we be doing wrong to cause this?
