How to use TimedFunc()
vince2e
Post by vince2e »
Hey guys I'm trying to get the timedFunc() working, but I'm having some issues.
I copied this code out of Help:
main()
int rc;
dyn_int weekDayList = makeDynInt( 1, 1, 3, 3, 6, 6 );
dyn_int timeList = makeDynInt( 61200, 64800, 61200, 64800, 57600, 61200 );
dpCreate( "testTimedFunc", "_TimedFunc" );
dpSet("testTimedFunc.weekDay", weekDayList,"testTimedFunc.time", timeList,
"testTimedFunc.mode", 1,"testTimedFunc.interval", 10 );
rc = timedFunc( "workFunc", "testTimedFunc" );
void workFunc( string dp, time before, time now, bool call )
DebugN( dp, before, now, call );
and it returns this error:
WCCOActrl (3), 2017.06.29 10:59:37.322, PARAM,SEVERE, 51, Parameter incorrect, TimedFunc, TimerScript.ctl::workFunc() Dp:testTimedFunc handleAnswer, Illegal parameterization, can't work!
Any Ideas? Thanks!
Re: How to use TimedFunc()
I've tested the example and it works.
For the test I made a modification to see if the work function is started. Instead of day 6 I used day 5. Also the timerange was changed to 3600, 61200 instead of 57600, 61200.
Which WinCC OA version are you using?
vince2e
Post by vince2e »
I'm using V3.15 P003 - windows AMD64.
I've made the changes you made I'm still getting the same error.
