DP functions
xavi.aran
DP functions
Post by xavi.aran »
I'm trying to use a personal function in the _dp_fct Config.
In the help it says:
You can also use functions with return value in this field.
It is possible? Where can i write my function? I try to put my function on a library project loaded in the config but doesn't work.
I send a images from para and LogViewer.
Thanks!
mweber
Re: DP functions
Post by mweber »
dont forget that dp_fcts are worked inside the event manager thus, when you want to use functions from whatever library inside the _dp_fct config, you have to load that library in the event section of your config file (or in your config.level of your sub-project).
example:
[event]
LoadCtrlLibs = "myLib.ctl"
best regards
Markus
baumanndo
Re: DP functions
Post by baumanndo »
how to load a ctrl library in Event at runtime?
adaneau
Re: DP functions
Post by adaneau »
I dont think it is possible, library are loaded at startup... Only gedi is having such an option.
Alexandre Daneau
Re: DP functions
As Alexandre has written dynamic loading of libraries is not possible in the Event Manager.
The libraries which are needed must be loaded with the config entries. If you have modified the code in the library the Event Manager must be restarted to use the new code.
