Supported / Unsupported mobile devices
nwischer
Post by nwischer »
Is there a list of supported / unsupported devices for WCCOA 3.15 mobile UI (Android, IOS) available ?
We are going to buy these tablets:
1. Samsung Galaxy Tab A T585 25,54 cm (10,1 Zoll) LTE Tablet-PC (Octa-Core, 2GB RAM, 16GB eMMC, Android 6.0, neue Version)
2. Apple iPad Pro ML0N2FD/A 32,8 cm (12,9 Zoll) Tablet PC
Additionally we want to find out how Desktop UI behaves on
- Microsoft Surface Pro 4 12,3“ Core i7 6650U 16 GB RAM - 1 TB SSD Herstellerteilenummer: SV4-00003
Are there any known limitations for these devices ?
Re: Supported / Unsupported mobile devices
We do not have a list of supported devices for the Mobile UI and the Desktop UI.
When using the Mobile UI you have to ensure that the device has one of the supported operating systems installed.
The information which version is supported you can get in the app store.
For the Desktop UI you have to use one of the supported operating systems listed in the WinCC OA documentation.
nwischer
Post by nwischer »
Thank you for your reply.
What about the hint in the WCCOA Help: "Im Moment wird das iPad Pro 12" nicht durch die WinCC OA mobile UI Applikation unterstützt!" (qthelp://wincc_oa/doc/Mobile_UI/mob_ui_req)
iPad Pro 12 is running with iOS9. Is it still not supported ?
The limitation for this specific iOS device is still valid.
The iPad Pro 12" is not supported.
Limitations for other devices are not known.
agruber
Post by agruber »
On an additional note. We do not support Android x86 at the moment. With your Android device you should be fine. In fact a use a similar one, Galaxy Tab A (2016) T580, its just WIFI only. Works great with WinCC OA.
BR,
Customer Care
The public iOS app store does not allow the usage of shared libraries. So control extensions, EWOs, TabUtilEx and other plugins cannot be easily used.
