I am trying to set up a system on 2 hosts as redundant system. I have 2 Dev licenses (Wincc OA V3.15) each one has following attributes in shield file:
redundancy = 1
para = 1
while trying to run the system, second redundant partner throws exception that "max number of instances (1) of para reached...."
is it possible to run a redundant system with this Dev license?
Para instances for a Redundant system
Re: Para instances for a Redundant system
Yes, a redundant system can be used with these licenses.
The count for ui and para is made for the redundant system and not for every server.
If you have para = 1 you can start 1 UI in configuration made (-extend, -m gedi, -m para) in your system.
Please modify the settings for the user interface at server 2.
- mjtaqi12
Thank you for the clarification. it works now.
