Line breaks in text field objects
7 posts • Page 1 of 1
afetzer
Post by afetzer »
we are desperately trying to insert line breaks into text fields.
While \\n, for example is working for primitive text, it isn't for text fields. I was wondering if someone in the community has more experience with that?
Thank you very much in advance for all support provided!
fmulder
Re: Line breaks in text field objects
Post by fmulder »
try \\r\\n (or \\n\\r)
share the fun
Frenk Mulder
joost.lijster@siemens.com
Post by joost.lijster@siemens.com »
Or, in case of rich formatting, use html ( )
RudiKreiner
Post by RudiKreiner »
. . . and in tool tip text you can use html formatting like in this example:
this.toolTipText = "" + dpGetDescription(dp_name) + "";
schneebergera
Post by schneebergera »
please use different text field.
--> "Multiline text"
e.g.
main()
this.text("first row\\r\\nsecond row!");
best regards,
fmulder
Post by fmulder »
I'd prefer the following syntax:
void main()
  this.text =
    "First line\\r\\n"          // Note how you can put a string on multiple lines !
    "Second row\\r\\n"
    "Third row";
or
void main()
  string strLinefeed = "\\r\\n";
  this.text =
    "First line"       + strLinefeed
    "Second row"  + strLinefeed
    "Third row";
Good luck with your multiline
Share + \\r\\n
The + \\r\\n
fun
Frenk Mulder
afetzer
Post by afetzer »
Many thanks for the input to everybody.
The main issue for us, thanks to your feedback, turned out to be that a text field element is not the right one for multi-line text, but we have to use the multi-line element.
Always good to learn something. Again, thank you very much.
