s7-plcsim with 3.15, problem tips
Gunhe213
Post by Gunhe213 »
Hi All
Someone that have had S7-PLCsim and 3.15 working together, I can not get connection up? I get State Host 1: Inactive, [mark Establish connection], [Apply], Connecting, Disconnected after approx 1-2min.
Im trying between WinCC OA 3.15 P002 and S7-PLCsim V13 SP1 with CPU-1500. PLC type: PLCsim, S7+ drive number is 2(Console S7Plus is 2 and started), Set PG/PC-interface is S7ONLINE(STEP 7)->PLCSIM S71200/S7-1500.TCPIP.1, Connection 1: 10.10.10.10(set in TIA-project), SCADA Export from Tia is no problem, Create of connection with TIA project S7+ symbolic selection works fine.
OA-log Viewer gives me:
WCCOAs7plus (2), 2017.05.09 15:07:18.013, CTRL, SEVERE, 12/s7plus, Login to PLC for Connection 1 failed with error -270
WCCOAs7plus (2), 2017.05.09 15:07:37.794, SYS, SEVERE, 94, Driver communication failure, failure condition on HmiConnection, _slussbro
Someone that knows what can be wrong?
Best regards
Gunnar
dhoegerl
Re: s7-plcsim with 3.15, problem tips
Post by dhoegerl »
Hello Gunnar!
As it says in the WinCC OA Help "PLCSim: For simulating ... (supported from TIA portal version 14 onwards)" we do not support connection to PLCSIM V13 but only V14 and newer.
Daniel
Gunhe213
Post by Gunhe213 »
It was that..G8, thanks
jm.diaz
Post by jm.diaz »
Hello Gunnar,
it is still possible to use NetToPLCSim (easy to find on Google) to connect WinCC OA 3.15 with PLCSim.
I am currently working with it and it works just fine.
B) B)
NetToPLCSim does not work with the S7-1200/S7-1500 family, it only works for the S7-300/S7-400 family (with PLCSIM V5.x).
For the S7-1200/S7-1500 family the options are:
- PLCSIM V14 (or newer) with the PLCSIM S71200/S7-1500 connection
- PLCSIM Advanced, which could run on a remote host (just like with NetToPLCSim)
jm.diaz
Post by jm.diaz »
Mea Culpa... :unsure:
I did not read properly the initial request, which actually concerns the S7-1200/1500 family.
In my case I am using it with S7-300/400 PLCs!
