Simulation Secren Problem
ASI27
Post by ASI27 »
Dear Developers,
I have simulation problem, there are anyone had the same problem like mine, how can we solve this problem.
The problem is that, I make my design on gedi panel, but when I running to the simulattor of gedi, I see similation secreen without any design.
I have this problem at only one of my project, at the same program my other project simulation runing is ok.
I use Wincc_oa 3.15 at win7_ 64bit
Any help would be appreciated, thanks all you from now.
Re: Simulation Secren Problem
can you please describe more detailed what is meant with "I see simulation screen without any design".
Do you see only an empty panel?
Is maybe the visibility of the object changed via script to set them invisible?
Are the errors reported in the PVSS_II.log file / at the logviewer (showing the content of the logfiles) when opening the panel?
ASI27
Post by ASI27 »
hello
I see semilation panel but here is not any object at simulation panel, I see only empty panel, all my object are visibel in scripts.
I have changed " [general] MessageDiagSec = 35 " this at config, but the problem is stil run.
at log viever:
1) WCCOAui (1), 2017.05.06 09:01:43.942, SYS, WARNING, 54, Unexpected state, Qt, QWindowsWindow::setGeometryDp: Unable to set geometry 1289x900+8+30 on QWidgetWindow/'QMainWindowClassWindow'. Resulting geometry: 1289x882+8+30 (frame: 8, 30, 8, 8, custom margin: 0, 0, 0, 0, minimum size: 69x69, maximum size: 16777215x16777215)
2) WCCOAui (1), 2017.05.06 09:02:56.408, CTRL, WARNING, 71, DP does not exist.
Thanks.
The first log message is only a warning when using a specfic function to open a panel. This log message has no influence on the functionality of the UI.
The second log message is truncated, therefore we cannot see which datapoint is missing.
The config entry MessageDiagSec is used for the message diagnostics in WinCC OA.
Why have you set this config entry?
Do you want to use the panel System Management --> Diagnostics --> Event-Man-Connections?
ASI27
Post by ASI27 »
When I get the problem I tyr to ameliorate it, so that I have been enter config.
If the problem solution is at panel of System Manegement --> Diagnostigs --> Event-man-cnnections, I need to enter it to solve the problem because I heve stiil this problem.
by the way I have MessageDiagSec=35 in config, after your post I deleted this from config.
Enosim - Support Specialist
Emin Dalg?c
