_Mod_Plc_1: PLC number-->1; Transaction timeout-->1000; Frame coding--> TCP; unit address: 0; List of Hosts: 192.168.1.31:5000
_Mod_Plc_2: PLC number-->2; Transaction timeout-->1000; Frame coding--> TCP; unit address: 0; List of Hosts: 192.168.1.31:5001
_Mod_Plc_3: PLC number-->3; Transaction timeout-->1000; Frame coding--> TCP; unit address: 0; List of Hosts: 192.168.1.31:5002
_Mod_Plc_4: PLC number-->4; Transaction timeout-->1000; Frame coding--> TCP; unit address: 0; List of Hosts: 192.168.1.31:5003
_Mod_Plc_5: PLC number-->5; Transaction timeout-->1000; Frame coding--> TCP; unit address: 0; List of Hosts: 192.168.1.31:5004
But when I start up the modbus driver -num 1, there seems some error shows in the log viewer:
WCCILpmon (1), 2017.04.21 09:47:21.921, SYS, INFO, 24/pmon, Got START command from ::1, starting the manager WCCOAmod(1) at index 21
WCCILpmon (1), 2017.04.21 09:47:21.923, SYS, INFO, 1, Manager Start, /opt/WinCC_OA/3.14/bin/WCCOAmod -PROJ DemoApplication_3.14 -pmonIndex 21 -num 1
WCCOAmod (1), 2017.04.21 09:47:21.942, SYS, INFO, 1, Manager Start, PROJ, DemoApplication_3.14, V 3.14 - 3.14 platform Linux x86_64 linked at Aug 2 2016 22:15:20
WCCOAmod (1), 2017.04.21 09:47:21.943, SYS, INFO, 3, Trying to connect to (SYS: 0 Data -num 0 CONN: 1) @ localhost:4897
WCCOAmod (1), 2017.04.21 09:47:21.944, SYS, INFO, 4, Connected to (SYS: 0 Data -num 0 CONN: 1) @ winccoa-demo.novalocal (::1)
WCCILdata (0), 2017.04.21 09:47:21.944, SYS, INFO, 4, Connected to (SYS: 1 Driver -num 1 CONN: 1) @ winccoa-demo.novalocal (::1)
WCCOAmod (1), 2017.04.21 09:47:21.958, PARAM,SEVERE, 50, Default branch called, ModHWMapper, addDpPa, Illegal transformation type for EXAMPLESERVER$ALERT$_mp_PUMP2alertmotorSwitch: 486
WCCOAmod (1), 2017.04.21 09:47:21.959, PARAM,SEVERE, 50, Default branch called, ModHWMapper, addDpPa, Illegal transformation type for EXAMPLESERVER$ALERT$_mp_PUMP2alertrunDry: 486
WCCOAmod (1), 2017.04.21 09:47:21.959, PARAM,SEVERE, 50, Default branch called, ModHWMapper, addDpPa, Illegal transformation type for EXAMPLESERVER$CMD$_mp_PUMP2cmdon: 482
WCCOAmod (1), 2017.04.21 09:47:21.959, PARAM,SEVERE, 50, Default branch called, ModHWMapper, addDpPa, Illegal transformation type for EXAMPLESERVER$STATE$_mp_PUMP2stateon: 486
WCCOAmod (1), 2017.04.21 09:47:21.959, PARAM,SEVERE, 50, Default branch called, ModHWMapper, addDpPa, Illegal transformation type for EXAMPLESERVER$STATE$_mp_PUMP2stateoff: 486
WCCOAmod (1), 2017.04.21 09:47:21.959, PARAM,SEVERE, 50, Default branch called, ModHWMapper, addDpPa, Illegal transformation type for EXAMPLESERVER$STATE$_mp_PUMP2statemoderemote: 486
WCCOAmod (1), 2017.04.21 09:47:21.959, PARAM,SEVERE, 50, Default branch called, ModHWMapper, addDpPa, Illegal transformation type for EXAMPLESERVER$STATE$_mp_PUMP2statemodelocal: 486
WCCOAmod (1), 2017.04.21 09:47:21.959, PARAM,SEVERE, 50, Default branch called, ModHWMapper, addDpPa, Illegal transformation type for EXAMPLESERVER$STATE$_mp_PUMP2statemodeauto: 486
WCCOAmod (1), 2017.04.21 09:47:21.959, PARAM,SEVERE, 50, Default branch called, ModHWMapper, addDpPa, Illegal transformation type for EXAMPLESERVER$STATE$_mp_PUMP2statemodeman: 486
WCCOAmod (1), 2017.04.21 09:47:21.960, PARAM,SEVERE, 54, Unexpected state, ModPollGroup, addItem, Cannot add poll address due to error in address M.3.3.0
WCCILdata (0), 2017.04.21 09:47:21.965, SYS, INFO, 0, , Manager (SYS: 1 Driver -num 1 CONN: 1) initialised
WCCOAmod (1), 2017.04.21 09:47:21.965, SYS, INFO, 6, Initialization by Data Manager finished
WCCOAmod (1), 2017.04.21 09:47:21.966, SYS, INFO, 3, Trying to connect to (SYS: 1 Event -num 0 CONN: 1) @ localhost:4998
WCCOAmod (1), 2017.04.21 09:47:21.966, SYS, INFO, 4, Connected to (SYS: 1 Event -num 0 CONN: 1) @ winccoa-demo.novalocal (::1)
WCCILevent (0), 2017.04.21 09:47:21.967, SYS, INFO, 4, Connected to (SYS: 1 Driver -num 1 CONN: 1) @ winccoa-demo.novalocal (::1)
WCCOAmod (1), 2017.04.21 09:47:21.969, SYS, SEVERE, 105, Invalid license, Driver will shutdown after the demo period of 604800 seconds
WCCOAmod (1), 2017.04.21 09:47:21.969, SYS, INFO, 156, Driver initialization finished., all items connected
WCCOAmod (1), 2017.04.21 09:47:21.973, SYS, INFO, 156, Driver initialization finished.
WCCOAmod (1), 2017.04.21 09:47:22.076, SYS, INFO, 0, , ModMasterConnection, masterConnEstablished, Established connection to 192.168.1.31 on port 5000
WCCOAmod (1), 2017.04.21 09:47:22.076, SYS, INFO, 0, , ModMasterConnection, masterConnEstablished, Established connection to 192.168.1.31 on port 5001
WCCOAmod (1), 2017.04.21 09:47:22.077, SYS, SEVERE, 13, Error while converting to engineers value, DP: (Type: 39 Sys: 1 Dp: 10875 El: 1 : _address..), MAN: (SYS: 1 Driver -num 1 CONN: 1), Value out of range for M.1.3.0
