How to latch or unlatch a datapoint?
yosu
Post by yosu »
How can I latch or unlatch a datapoint?
I want to set to true datapoint1 when datapoint2 is true, don't mind datapoint3 value, and set to false only when datapoint3 is false, don't mind datapoint2 value.
nmnogueira
Re: How to latch or unlatch a datapoint?
Post by nmnogueira »
Create a script associated with a contol manager.
Do something like:
main()
  dpConnect("work2","datapoint2", "datapoint3");
work(dp2,val2,dp3,val3)
  if(val2)
    dpSet("datapoint1",1);
  if(!val3)
    dpSet("datapoint1",0);
I prefer always to not connect to more datapoint elements then needed. So in this case I prefer split the dpConnect into two, since the behavior does not depend on the other datapoint element.
yosu
Post by yosu »
Thanks for your answer
ozangor
Post by ozangor »
You may also use the dp_funct config in order to achieve this.
first = second || (!second && third);
nmnogueira
Dear Ozan
I think that solution does not work.
e.g. if third = FALSE
first = second || (!second && FALSE) = second || FALSE == second
I think it's possible to do it with a DP function, but you would have to use "Initialize global variable" and create a script for it.
