I'm trying to make some BIRT reports with 3.14, and keep getting an error "SOAP-ENV: Client HTTP GET method not implemented" from reporting manager. That error is shown, when I'm trying to pass ip:port as URL (in DemoApplication, for example).
But everything works fine (data from my process is shown), when I open the report from the BIRT by the Run-View Report-In Web Viewer (ip 127.0.0.1 and some port like 58601).
I was trying to change port number in config, but no success.
Is there any solution for this problem?
BIRT Reporting. \"Client HTTP GET method not implemented\" error.
- LIGO
- Andorhal
Re: BIRT Reporting. \"Client HTTP GET method not implemented\" error.
Hello.
I would assume some kind of port communication issue.
For the Demo Application Birt Panel to run properly some things should be kept in mind:
If you need to reset the preview Server IP/port combo pls do so at the (internal) _Reporting DP.
BR Robert
- In Birt you can set the port of the preview Server: Window-> Preferences -> Report design -> Preview -> Preview Server (otherwise it will be changed with every start).
- In the WinCC OA config file you specify which port the Reporting Manager shall use (see product help)
- In the reporting template you have to tell birt where the data source is located (=the Reporting Manager IP/port).
BR Robert
- LIGO
Thank you very much, Robert, for pointing out on Preview Server.
I thought, WinCC OA Reporting manager is working as some kind of web-server (so it responsible for showing final report) and that was my main issue.
Today I tried a BIRT-runtime and tomcat, which worked out perfectly well for my task.
- Andorhal
Glad you could work it out.
The Reporting Manager "only" acts as SOAP interface providing the WSDL to a client (BIRT, ...).
Birt in fact has a built in Webserver (Jetty), by running a report it is started an then displays the reports.
Birt Runtime and Tomcat is also our recommended setting to go for production.
