Dear All,
We have a case which we have 1024 dyn_int DP elements and each is around 3000 int arrays. Due to this we are getting error: -909 file record limit exceeded for last val DB. Size is around 200 MB. Can you give an advise to get rid of this situation. Can we let OA to expand DB size?
Best Regards,
last value DB
Re: last value DB
if you get the information "file record limit exceeded" it can have different causes. To see which part of the database is really affected you can follow the instructions described in the following FAQ
