Sumalert Generation
paramesh1985
Sumalert Generation
Post by paramesh1985 »
We created the sumalert config under alarm node and defined the DP Pattern (DPName.*.**) in the Alerts tab with priority (116-220).
And we run the sum alert generation via panel topology. But the alarm dpe elements are not listed in the respective sumalert dp.
In the alerts tab we can see only $DP.alarm no dpe element is listed.
Its necessary to define all the required alert dpe element in the "object" Acknowledge property wizard.
If we didn't define the alert dpe element in the "Object" Acknowledge property wizard sum alert and group acknowledgement will not work.
In the help we could not able to find more information
Re: Sumalert Generation
If I understood it correctly:
- You have defined '$DP.alarm' in the 'Acknowledge' property of an object
- In the panel topology you have generated the sum alerts
- In the '_SumAlertPanel' datapoints you do not see the default '_TmpBitAlert.', but what you have defined in the 'Acknowledge' properties
I am missing the link between the sumalert config and the $DP. Where did you specify the datapoint for '$DP'? In the panel topology? Or in a panel?
When you specify a sumalert in the 'Acknowledge' property the '_SumAlertPanel' will contain this sumalert not its summed alerts.
