Communication Driver for Siemens CP1430 TF (6GK1143-0TA02)
- rpf
Does the version 3.14 of WinCC OA support H1 communication to old Siemens CPs like CP1430 TF (6GK1143-0TA02)? Is there a communication driver available for S5-150 / S5-135 / S5-155?
Re: Communication Driver for Siemens CP1430 TF (6GK1143-0TA02)
The 3.14 S7 driver is the last version with support for S5 (TCP). Since 3.15 S5 support has been dropped.
- RudiKreiner
I'm quite sure driver mentioned above uses the TCP protokoll, not the H1 protokoll as you had requested, so be aware of that. If you want to use the TCP protocol, make sure that the CP board that you have suppots it
