Dear all,
I like to use WINCC OA on a Windows PC with installed HiPath telephone system dialer Simplyphone this uses the same TCP Port 4999 as PVSS00pmon.exe. Is there a possibility to change the used TCP Port of WinCC OA? Simplyphone doesn't allow this.
Thanks an greetings
Daniel
Unable to start managers on tcp port 4999
- daniel.ponader
- mweber
Re: Unable to start managers on tcp port 4999
of course you could change the ports WinCC OA uses for communication.
(the port 4999 is the default port for the pmon - our process monitor)
simply add those line to your config file (into the [general] section):
pmonPort = 6000
you could as well change the ports of other managers that act as a communication master:
eventPort =
dataPort =
distPort =
reduPort =
Be sure that you always delimit the last line in the config file with an !
btw: the Pmon port can also be changed at the project administration panel when opening the project properties.
have fun
Markus
P.S.: we will meet each other in KW6 for the basic training...
pmonPort = 6000
eventPort =
dataPort =
distPort =
reduPort =
have fun
Markus
- aorange
Of course this is also useful to know to run multiple WinCC-OA projects on the same platform..
please notice that running several projects at the same time on one machine is only allowed for the project-engineering.
In real runtime systems you have to start only one project at one machine.
