is there a way to reset GEDI to its original layout ?
GEDI configuration reset
Re: GEDI configuration reset
yes. Remove the file ~/.config/ETM/PVSS00ui.ini
- RudiKreiner
Martin gave you the path to find the file on a linux machine.
In Windows you will find it in C:\\Users\\%UserName%\\AppData\\Roaming\\ETM\\PVSS00ui.ini
