Hello everybody
Someone has experience in implementing a SOAP interface in WinCC OA, same as xmlRPC?
Thanks for all useful hints or suggestions.
regards
SOAP for Communication with other System
- fmulder
Re: SOAP for Communication with other System
I remember implementing a SOAP interface to a Barco Apolly system (videowall).
I used gsoap ( https://en.wikipedia.org/wiki/GSOAP ) to generate a C++ wrapper which i then used from a C++ Control DLL.
It is quite some years ago. I'm pretty sure that I first looked at scripting. Not sure why I decided to go for C++
Good luck
"share the fun"
Frenk Mulder
Good luck
"share the fun"
Frenk Mulder
- juma4
Thank you for your hint. This helped me a lot.
- lukas.schopp
may you have a look on the reporting manager of OA.
This is a SOAP manger with some defined functions.
Maybe this helps?.
Best wishes
Lukas Schopp
WinCC OA Product Manager
Maybe this helps?.
Best wishes
Lukas Schopp
- juma4
Guten Morgen Herr Schopp
Ich hoffe ich kann hier auch in Deutsch schreiben.
Ist es möglich zusätzliche Funktionen zum Reporting Manager hinzuzufügen?
Ich benötige die Möglichkeit Datenpunkte zu setzten, und eine quittierung zu senden.
Grüsse aus der Schweiz
Markus Junker
Markus Junker
- Andorhal
Hallo Hr. Junker,
bitte haben sie Verständnis - damit alle Forumsmitglieder an der Kommunikation teilhaben können - das die primäre Sprache hier Englisch ist.
Currently it is not possible to have a dpSet or alarm acknowledgement via the Reporting Manager as it only provides the (unidirectional) predefined functions.
BTW: The Manager also uses an implementation based on gSOAP.
Best regards
Robert Weinberger
Best regards
Robert Weinberger
