How to encrypt panels, libraries and scripts?
deepaktony
Post by deepaktony »
Hi...!!!
I am using the WinCC OA 3.14 version.
We need the lock the panels, libraries and scripts through encryption.
Any one help me on these encryption. Is there any additional tool or addin/setup required for it???
lebethc
Re: How to encrypt panels, libraries and scripts?
Post by lebethc »
there are some tools in WinCC OA which can be used for encryption of scripts or panel.
You will find detailed information about this topic in the WinCC OA help (Special functions / Encryption of Panels and CTRL-Scripts) or you search for "encryption".
Christoph
nmnogueira
Post by nmnogueira »
Be aware that when you encrypt a panel, there is no way to decrypt it! So make sure that you make a copy of the panels before encrypting them.
fmulder
Post by fmulder »
The best approach is:
- put your script code in libraries
- panels should only contain shapes and some function calls
- Encrypt your libraries
- Do not encrypt your panels !!!!!
The fact that you can't decrypt the panel doesn't have to be a problem. The real risk that you run is the fact that you don't see that the panel is encrypted. The extension is still *.pnl.
That is : i recently ran into a project and had to change a panel. I then found out that the panel was encrypted and that I had to reverse-engineer the panel just by looking at the shapes.
Good luck
"Share the fun"
Frenk Mulder
