\"Error during caching stage\" during WinCC OA 3.15 setup
cplasse
Post by cplasse »
I had "Error during caching stage" during WinCC OA 3.15 setup" message when I try to install WinCC OA 3.15 on Windows 2012 R2.
I use "Administrator" as login so it is not a permission problem. I have the same problem on 2 machines, one is a clean Windows 2012 R2 install.
Did someone have this problem ?
Regards.
tmalone
Re: \"Error during caching stage\" during WinCC OA 3.15 setup
Post by tmalone »
just for fun, right click on setup.exe and choose "run as administrator" and try it again.
agruber
Post by agruber »
And if that does not help, check if you have enough disc space for the Windows Installer cache on your C drive. You will probably need 2 to 3 GB.
Also verify the integrity of the setup, you can check it with the properties of the digital signature.
Sometimes Windows has some pending updates which prevent a successful installation, a reboot could help in that case.
If that all does not help, create a copy of the install logs (find them in %temp% ) when the error dialogue is still visible and send them to your common WinCC OA support.
BR,
cplasse
Post by cplasse »
I downloaded again 3.15 version and setup works now. File was corrupt...
Thanks for help
tmalone
bad size on download
Post by tmalone »
this error also appears when you have an incomplete download of the installer. You can see if it is bad by checking size of the download against what is expected.
I see this when I download multiple files at the same time from the ETM site.
Todd Malone
Re: \
If you want to check if the downloaded file is correct you can generate a SHA256 check sum and compare it with the information given at the page for the patch download.
