Desktop UI - Could not get server version
11 posts • Page 1 of 2
MrKintaro
Post by MrKintaro »
I am trying in WinCC OA 3.15 the new Desktop UI but I am not able to run UI.
Configuration: WinCC OA locally installed and UI on the same PC.
I am performing the followings steps:
Start the webclient_http.ctl and getting the following error in the log:
WCCOActrl    (2), 2017.02.21 09:01:21.233, CTRL, SEVERE,      5/ctrl, Location of the following log entry: webclient_http.ctl    Line: 59
WCCOActrl    (2), 2017.02.21 09:01:21.233, SYS,  SEVERE,      1/http, The Port 443 could not be opened.
WCCOActrl    (2), 2017.02.21 09:01:21.249, CTRL, WARNING,    54, Unexpected state, httpServer could not be started
I don´t know but the 443 can not be opened on my company PC.
I tried in the firewall to create a rule but it doesn't bring anything.
Never the less the help says : To install the required HTTP server you just add a new CTRL manager to your project, add "webclient_http.ctl" as parameter to it and start the manager. By default your HTTP server is now reachable under the IP or host name (DNS or hosts file entry required) and the ports 80 (no SSL) or 443 (SSL).
In my understanding port 8 or 443.
After I start (as administrator) the WinCC OA Desktop UI 3.15 x64 and enter the following config:
localhost, nothing more. have a look ion the image.
Start thw UI and getting the second image error: could not get server version.
here the log file:
Error in communication with HTTP server:
http://localhost:80/_info?clientUpdateCheck=x&major=3&minor=15&patch=1&arch=windows-64
Connection refused
But I don´t know why.
I tried to have a look in the Device Management to unlock the device but nothing change.
Some help please. Image
Re: Desktop UI - Could not get server version
When the http server can not open a port, it has nothing to do with a firewall.
A firewall defines rules which ports should be accessible, but in your case, the http server can not even open the socket on the given port.
This might be due to another program having this port already occupied.
Check with netstat.
MrKintaro
Post by MrKintaro »
you are right I also thought the same but no other service using the port
Ant1968
Post by Ant1968 »
Hallo,
I think the behavior you described is a by default one.
In fact in the online help of WinCC 3.15 (section Desktiop UI) is written as it follows:
For bypassing this bydesign feature I tried to add the following entry in the config file of my test project:
[webClient]
panel = "vision/login.pnl"
httpPort = 0
httpsPort = 443
Take care,
Antonio
MrKintaro
Post by MrKintaro »
Done it, did not work.
The strange things I am doing that in the DemoApplication and is not working.
When I am connceting to the demo.etm.at is working.
here the logs files.
Log File Desktop UI
http://localhost:80/_info?sessionToken=x
Connection refused
Connection refused
Log File
Removed becase was wrong
Ant1968
Post by Ant1968 »
Hallo Denis,
in your log I see the following:
2/http, Server listens on Port https:// - 8443.
If you use my entry the entry should be something like:
2/http, Server listens on Port https:// - 443.
Maybe a typo?
Moreover , If I am not wrong, you are trying to connect using http and not https.
Mine was just a sample, you can use whatever port or protocol you prefer, obviously.
MrKintaro
Post by MrKintaro »
Sorry,
I copy a wrong log file.
I entered a correct port. after the correct log.
I did not understand your comment.
but it doesn´t metter which I am using, also with https is not working.
https://localhost:443/_info?sessionToken=x
Error downloading https://localhost:443/_info?sessionToken=x - server replied: Not Found
https://localhost:443/_info?clientUpdateCheck=x&major=3&minor=15&patch=1&arch=windows-64
Error downloading https://localhost:443/_info?clientUpdateCheck=x&major=3&minor=15&patch=1&arch=windows-64 - server replied: Not Found
LOG FILE
WCCILpmon    (1), 2017.02.21 13:37:23.322, SYS,  INFO,       20/pmon, Got START_ALL command from 127.0.0.1, starting the project
WCCILpmon    (1), 2017.02.21 13:37:24.359, SYS,  INFO,        1, Manager Start, D:\\Siemens\\Automation\\WinCC_OA\\3.15\\bin\\WCCILdata.exe -PROJ DemoApplication_3.15 -pmonIndex 1
WCCILdata    (0), 2017.02.21 13:37:24.461, SYS,  INFO,        1, Manager Start, PROJ, DemoApplication_3.15, V 3.15 - 3.15   platform Windows AMD64 linked at Jan 15 2017 22:10:59
WCCILdata    (0), 2017.02.21 13:37:24.473, SYS,  INFO,        0, , (Re)Opening databases in single user mode without transaction logging.
WCCILdata    (0), 2017.02.21 13:37:25.318, SYS,  INFO,        0, , Initialize archive smoothing
WCCILdata    (0), 2017.02.21 13:37:25.333, SYS,  INFO,        0, , Loading DpIdentification
WCCILdata    (0), 2017.02.21 13:37:25.380, SYS,  INFO,        0, , Initializing last value cache
WCCILdata    (0), 2017.02.21 13:37:25.458, SYS,  INFO,        0, , Loading internal datapoints
WCCILdata    (0), 2017.02.21 13:37:25.458, SYS,  INFO,        0, , Initializing ID history
WCCILdata    (0), 2017.02.21 13:37:25.474, SYS,  INFO,        0, , Initializing Alert history
WCCILdata    (0), 2017.02.21 13:37:25.474, SYS,  INFO,        0, , Initializing Alert Class cache
WCCILdata    (0), 2017.02.21 13:37:25.489, SYS,  INFO,        6, Initialization by Data Manager finished
WCCILdata    (0), 2017.02.21 13:37:25.520, SYS,  INFO,        0, , Initializing Value Archives
WCCILdata    (0), 2017.02.21 13:37:25.536, SYS,  INFO,        0, , ValueArchive will be used...
WCCILpmon    (1), 2017.02.21 13:37:25.598, SYS,  INFO,        1, Manager Start, D:\\Siemens\\Automation\\WinCC_OA\\3.15\\bin\\WCCOAvalarch.exe -PROJ DemoApplication_3.15 -pmonIndex 2 -num 0
WCCOAvalarch (0), 2017.02.21 13:37:25.661, SYS,  INFO,        1, Manager Start, PROJ, DemoApplication_3.15, V 3.15 - 3.15   platform Windows AMD64 linked at Jan 15 2017 22:10:59
WCCOAvalarch (0), 2017.02.21 13:37:25.676, SYS,  INFO,        3, Trying to connect to (SYS: 0 Data -num 0 CONN: 1) @ localhost:4897
WCCOAvalarch (0), 2017.02.21 13:37:25.692, SYS,  INFO,        4, Connected to (SYS: 0 Data -num 0 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:25.708, SYS,  INFO,        4, Connected to (SYS: 1 Data -num 2 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:25.708, PARAM,INFO,        1, Manager Start, HistOrgMain, connection from archive received - initializing, archive number is: 0
WCCILdata    (0), 2017.02.21 13:37:25.739, SYS,  INFO,        0, , Manager (SYS: 1 Data -num 2 CONN: 1) initialised
WCCILpmon    (1), 2017.02.21 13:37:25.848, SYS,  INFO,        1, Manager Start, D:\\Siemens\\Automation\\WinCC_OA\\3.15\\bin\\WCCOAvalarch.exe -PROJ DemoApplication_3.15 -pmonIndex 3 -num 1
WCCOAvalarch (1), 2017.02.21 13:37:25.910, SYS,  INFO,        1, Manager Start, PROJ, DemoApplication_3.15, V 3.15 - 3.15   platform Windows AMD64 linked at Jan 15 2017 22:10:59
WCCOAvalarch (1), 2017.02.21 13:37:25.926, SYS,  INFO,        3, Trying to connect to (SYS: 0 Data -num 0 CONN: 1) @ localhost:4897
WCCOAvalarch (1), 2017.02.21 13:37:25.926, SYS,  INFO,        4, Connected to (SYS: 0 Data -num 0 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:25.942, SYS,  INFO,        4, Connected to (SYS: 1 Data -num 3 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:25.942, PARAM,INFO,        1, Manager Start, HistOrgMain, connection from archive received - initializing, archive number is: 1
WCCILdata    (0), 2017.02.21 13:37:25.973, SYS,  INFO,        0, , Manager (SYS: 1 Data -num 3 CONN: 1) initialised
WCCILpmon    (1), 2017.02.21 13:37:26.113, SYS,  INFO,        1, Manager Start, D:\\Siemens\\Automation\\WinCC_OA\\3.15\\bin\\WCCOAvalarch.exe -PROJ DemoApplication_3.15 -pmonIndex 4 -num 2
WCCOAvalarch (2), 2017.02.21 13:37:26.191, SYS,  INFO,        1, Manager Start, PROJ, DemoApplication_3.15, V 3.15 - 3.15   platform Windows AMD64 linked at Jan 15 2017 22:10:59
WCCOAvalarch (2), 2017.02.21 13:37:26.207, SYS,  INFO,        3, Trying to connect to (SYS: 0 Data -num 0 CONN: 1) @ localhost:4897
WCCOAvalarch (2), 2017.02.21 13:37:26.207, SYS,  INFO,        4, Connected to (SYS: 0 Data -num 0 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:26.222, SYS,  INFO,        4, Connected to (SYS: 1 Data -num 4 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:26.238, PARAM,INFO,        1, Manager Start, HistOrgMain, connection from archive received - initializing, archive number is: 2
WCCILdata    (0), 2017.02.21 13:37:26.254, SYS,  INFO,        0, , Manager (SYS: 1 Data -num 4 CONN: 1) initialised
WCCILpmon    (1), 2017.02.21 13:37:26.347, SYS,  INFO,        1, Manager Start, D:\\Siemens\\Automation\\WinCC_OA\\3.15\\bin\\WCCOAvalarch.exe -PROJ DemoApplication_3.15 -pmonIndex 5 -num 3
WCCOAvalarch (3), 2017.02.21 13:37:26.410, SYS,  INFO,        1, Manager Start, PROJ, DemoApplication_3.15, V 3.15 - 3.15   platform Windows AMD64 linked at Jan 15 2017 22:10:59
WCCOAvalarch (3), 2017.02.21 13:37:26.425, SYS,  INFO,        3, Trying to connect to (SYS: 0 Data -num 0 CONN: 1) @ localhost:4897
WCCOAvalarch (3), 2017.02.21 13:37:26.441, SYS,  INFO,        4, Connected to (SYS: 0 Data -num 0 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:26.456, SYS,  INFO,        4, Connected to (SYS: 1 Data -num 5 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:26.456, PARAM,INFO,        1, Manager Start, HistOrgMain, connection from archive received - initializing, archive number is: 3
WCCILdata    (0), 2017.02.21 13:37:26.472, SYS,  INFO,        0, , Manager (SYS: 1 Data -num 5 CONN: 1) initialised
WCCILpmon    (1), 2017.02.21 13:37:26.566, SYS,  INFO,        1, Manager Start, D:\\Siemens\\Automation\\WinCC_OA\\3.15\\bin\\WCCOAvalarch.exe -PROJ DemoApplication_3.15 -pmonIndex 6 -num 4
WCCOAvalarch (4), 2017.02.21 13:37:26.628, SYS,  INFO,        1, Manager Start, PROJ, DemoApplication_3.15, V 3.15 - 3.15   platform Windows AMD64 linked at Jan 15 2017 22:10:59
WCCOAvalarch (4), 2017.02.21 13:37:26.644, SYS,  INFO,        3, Trying to connect to (SYS: 0 Data -num 0 CONN: 1) @ localhost:4897
WCCOAvalarch (4), 2017.02.21 13:37:26.659, SYS,  INFO,        4, Connected to (SYS: 0 Data -num 0 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:26.659, SYS,  INFO,        4, Connected to (SYS: 1 Data -num 6 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:26.675, PARAM,INFO,        1, Manager Start, HistOrgMain, connection from archive received - initializing, archive number is: 4
WCCILdata    (0), 2017.02.21 13:37:26.675, SYS,  INFO,        0, , Manager (SYS: 1 Data -num 6 CONN: 1) initialised
WCCILpmon    (1), 2017.02.21 13:37:26.800, SYS,  INFO,        1, Manager Start, D:\\Siemens\\Automation\\WinCC_OA\\3.15\\bin\\WCCOAvalarch.exe -PROJ DemoApplication_3.15 -pmonIndex 7 -num 5
WCCOAvalarch (5), 2017.02.21 13:37:26.878, SYS,  INFO,        1, Manager Start, PROJ, DemoApplication_3.15, V 3.15 - 3.15   platform Windows AMD64 linked at Jan 15 2017 22:10:59
WCCOAvalarch (5), 2017.02.21 13:37:26.893, SYS,  INFO,        3, Trying to connect to (SYS: 0 Data -num 0 CONN: 1) @ localhost:4897
WCCOAvalarch (5), 2017.02.21 13:37:26.893, SYS,  INFO,        4, Connected to (SYS: 0 Data -num 0 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:26.909, SYS,  INFO,        4, Connected to (SYS: 1 Data -num 7 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:26.909, PARAM,INFO,        1, Manager Start, HistOrgMain, connection from archive received - initializing, archive number is: 5
WCCILdata    (0), 2017.02.21 13:37:26.924, SYS,  INFO,        0, , Manager (SYS: 1 Data -num 7 CONN: 1) initialised
WCCOAvalarch (0), 2017.02.21 13:37:28.750, SYS,  INFO,        6, Initialization by Data Manager finished
WCCILdata    (0), 2017.02.21 13:37:28.765, SYS,  INFO,        0, , Sending initial values to archive
WCCOAvalarch (1), 2017.02.21 13:37:28.984, SYS,  INFO,        6, Initialization by Data Manager finished
WCCILdata    (0), 2017.02.21 13:37:28.999, SYS,  INFO,        0, , Sending initial values to archive
WCCOAvalarch (2), 2017.02.21 13:37:29.280, SYS,  INFO,        6, Initialization by Data Manager finished
WCCILdata    (0), 2017.02.21 13:37:29.311, SYS,  INFO,        0, , Sending initial values to archive
WCCOAvalarch (3), 2017.02.21 13:37:29.545, SYS,  INFO,        6, Initialization by Data Manager finished
WCCILdata    (0), 2017.02.21 13:37:29.561, SYS,  INFO,        0, , Sending initial values to archive
WCCOAvalarch (4), 2017.02.21 13:37:29.732, SYS,  INFO,        6, Initialization by Data Manager finished
WCCILdata    (0), 2017.02.21 13:37:29.748, SYS,  INFO,        0, , Sending initial values to archive
WCCOAvalarch (0), 2017.02.21 13:37:29.795, SYS,  INFO,        0, , Ready for operation.
WCCOAvalarch (5), 2017.02.21 13:37:29.982, SYS,  INFO,        6, Initialization by Data Manager finished
WCCILdata    (0), 2017.02.21 13:37:30.013, SYS,  INFO,        0, , Sending initial values to archive
WCCILpmon    (1), 2017.02.21 13:37:30.029, SYS,  INFO,        1, Manager Start, D:\\Siemens\\Automation\\WinCC_OA\\3.15\\bin\\WCCILevent.exe -PROJ DemoApplication_3.15 -pmonIndex 8
WCCOAvalarch (1), 2017.02.21 13:37:30.044, SYS,  INFO,        0, , Ready for operation.
WCCILevent   (0), 2017.02.21 13:37:30.091, SYS,  INFO,        1, Manager Start, PROJ, DemoApplication_3.15, V 3.15 - 3.15   platform Windows AMD64 linked at Jan 15 2017 22:10:59
WCCILevent   (0), 2017.02.21 13:37:30.107, SYS,  INFO,      108, License information, Host information
Hostname:   MD1KH1GC
HW-code:    00198361790
HW-version: 31500002
WCCILevent   (0), 2017.02.21 13:37:30.122, SYS,  SEVERE,    105, Invalid license, Demo license found
WCCILevent   (0), 2017.02.21 13:37:30.122, SYS,  INFO,      108, License information, Using license file D:\\Siemens\\Automation\\WinCC_OA\\3.15\\shield.txt
WCCILevent   (0), 2017.02.21 13:37:30.138, SYS,  INFO,        3, Trying to connect to (SYS: 0 Data -num 0 CONN: 1) @ localhost:4897
WCCILevent   (0), 2017.02.21 13:37:30.138, SYS,  INFO,        4, Connected to (SYS: 0 Data -num 0 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:30.154, SYS,  INFO,        4, Connected to (SYS: 1 Event -num 0 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILevent   (0), 2017.02.21 13:37:30.169, SYS,  SEVERE,    105, Invalid license, Demo license found
WCCOAvalarch (2), 2017.02.21 13:37:30.325, SYS,  INFO,        0, , Ready for operation.
WCCILdata    (0), 2017.02.21 13:37:30.372, SYS,  INFO,        0, , Manager (SYS: 1 Event -num 0 CONN: 1) initialised
WCCILevent   (0), 2017.02.21 13:37:30.388, SYS,  INFO,        6, Initialization by Data Manager finished
WCCILevent   (0), 2017.02.21 13:37:30.388, SYS,  INFO,      169, Initialize 249 dp-functions
WCCILevent   (0), 2017.02.21 13:37:30.419, SYS,  INFO,      168, Initialize 407 alerts
WCCILevent   (0), 2017.02.21 13:37:30.434, SYS,  SEVERE,    105, Invalid license, Eventmanager will shutdown after the demo period of 43200 seconds
WCCILevent   (0), 2017.02.21 13:37:30.466, SYS,  INFO,      103, User names/passwords initialized
WCCILpmon    (1), 2017.02.21 13:37:30.481, SYS,  INFO,        1, Manager Start, D:\\Siemens\\Automation\\WinCC_OA\\3.15\\bin\\WCCILproxy.exe -PROJ DemoApplication_3.15 -pmonIndex 9
WCCILproxy   (1), 2017.02.21 13:37:30.544, SYS,  INFO,      220, Multiplexing proxy Start, PROJ, DemoApplication_3.15, V 3.15 - 3.15   platform Windows AMD64 linked at Jan 15 2017 22:10:59
WCCOAvalarch (3), 2017.02.21 13:37:30.575, SYS,  INFO,        0, , Ready for operation.
WCCILproxy   (1), 2017.02.21 13:37:30.668, SYS,  INFO,        0, , Can maintain up to 4088 concurrent connections
WCCILpmon    (1), 2017.02.21 13:37:30.746, SYS,  INFO,        1, Manager Start, D:\\Siemens\\Automation\\WinCC_OA\\3.15\\bin\\WCCILsim.exe -PROJ DemoApplication_3.15 -pmonIndex 10
WCCOAvalarch (4), 2017.02.21 13:37:30.778, SYS,  INFO,        0, , Ready for operation.
WCCILsim     (1), 2017.02.21 13:37:30.793, SYS,  INFO,        1, Manager Start, PROJ, DemoApplication_3.15, V 3.15 - 3.15   platform Windows AMD64 linked at Jan 15 2017 22:10:59
WCCILsim     (1), 2017.02.21 13:37:30.809, SYS,  INFO,        3, Trying to connect to (SYS: 0 Data -num 0 CONN: 1) @ localhost:4897
WCCILsim     (1), 2017.02.21 13:37:30.824, SYS,  INFO,        4, Connected to (SYS: 0 Data -num 0 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:30.824, SYS,  INFO,        4, Connected to (SYS: 1 Driver -num 1 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:30.871, SYS,  INFO,        0, , Manager (SYS: 1 Driver -num 1 CONN: 1) initialised
WCCILsim     (1), 2017.02.21 13:37:30.871, SYS,  INFO,        6, Initialization by Data Manager finished
WCCILsim     (1), 2017.02.21 13:37:30.887, SYS,  INFO,        3, Trying to connect to (SYS: 1 Event -num 0 CONN: 1) @ localhost:4998
WCCILsim     (1), 2017.02.21 13:37:30.887, SYS,  INFO,        4, Connected to (SYS: 1 Event -num 0 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILevent   (0), 2017.02.21 13:37:30.902, SYS,  WARNING,   105, Invalid license, Demo license found, Running as demo version, driver
WCCILevent   (0), 2017.02.21 13:37:30.902, SYS,  INFO,        4, Connected to (SYS: 1 Driver -num 1 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILsim     (1), 2017.02.21 13:37:30.918, SYS,  SEVERE,    105, Invalid license, Driver will shutdown after the demo period of 43200 seconds
WCCILsim     (1), 2017.02.21 13:37:30.918, SYS,  INFO,      156, Driver initialization finished.
WCCILsim     (1), 2017.02.21 13:37:30.934, SYS,  INFO,      156, Driver initialization finished., all items connected
WCCILpmon    (1), 2017.02.21 13:37:30.980, SYS,  INFO,        1, Manager Start, D:\\Siemens\\Automation\\WinCC_OA\\3.15\\bin\\WCCOActrl.exe -PROJ DemoApplication_3.15 -pmonIndex 11 -f pvss_scripts.lst
WCCOAvalarch (5), 2017.02.21 13:37:31.027, SYS,  INFO,        0, , Ready for operation.
WCCOActrl    (0), 2017.02.21 13:37:31.058, SYS,  INFO,        1, Manager Start, PROJ, DemoApplication_3.15, V 3.15 - 3.15   platform Windows AMD64 linked at Jan 15 2017 22:10:59
WCCOActrl    (0), 2017.02.21 13:37:31.074, SYS,  INFO,        3, Trying to connect to (SYS: 0 Data -num 0 CONN: 1) @ localhost:4897
WCCOActrl    (0), 2017.02.21 13:37:31.074, SYS,  INFO,        4, Connected to (SYS: 0 Data -num 0 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:31.090, SYS,  INFO,        4, Connected to (SYS: 1 Ctrl -num 1 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:31.090, SYS,  INFO,        0, , Manager (SYS: 1 Ctrl -num 1 CONN: 1) initialised
WCCOActrl    (1), 2017.02.21 13:37:31.105, SYS,  INFO,        6, Initialization by Data Manager finished
WCCOActrl    (1), 2017.02.21 13:37:31.105, SYS,  INFO,        3, Trying to connect to (SYS: 1 Event -num 0 CONN: 1) @ localhost:4998
WCCOActrl    (1), 2017.02.21 13:37:31.121, SYS,  INFO,        4, Connected to (SYS: 1 Event -num 0 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILevent   (0), 2017.02.21 13:37:31.121, SYS,  WARNING,   105, Invalid license, Demo license found, Running as demo version, ctrl
WCCILevent   (0), 2017.02.21 13:37:31.136, SYS,  INFO,        4, Connected to (SYS: 1 Ctrl -num 1 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCOActrl    (1), 2017.02.21 13:37:31.136, SYS,  INFO,      102, Waiting for user names/passwords
WCCOActrl    (1), 2017.02.21 13:37:31.136, SYS,  INFO,      103, User names/passwords initialized
WCCILpmon    (1), 2017.02.21 13:37:31.214, SYS,  INFO,        1, Manager Start, D:\\Siemens\\Automation\\WinCC_OA\\3.15\\bin\\WCCOActrl.exe -PROJ DemoApplication_3.15 -pmonIndex 12 -f pid_scripts.lst
WCCOActrl    (0), 2017.02.21 13:37:31.277, SYS,  INFO,        1, Manager Start, PROJ, DemoApplication_3.15, V 3.15 - 3.15   platform Windows AMD64 linked at Jan 15 2017 22:10:59
WCCOActrl    (0), 2017.02.21 13:37:31.292, SYS,  INFO,        3, Trying to connect to (SYS: 0 Data -num 0 CONN: 1) @ localhost:4897
WCCOActrl    (0), 2017.02.21 13:37:31.292, SYS,  INFO,        4, Connected to (SYS: 0 Data -num 0 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:31.308, SYS,  INFO,        4, Connected to (SYS: 1 Ctrl -num 2 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:31.324, SYS,  INFO,        0, , Manager (SYS: 1 Ctrl -num 2 CONN: 1) initialised
WCCOActrl    (2), 2017.02.21 13:37:31.324, SYS,  INFO,        6, Initialization by Data Manager finished
WCCOActrl    (2), 2017.02.21 13:37:31.324, SYS,  INFO,        3, Trying to connect to (SYS: 1 Event -num 0 CONN: 1) @ localhost:4998
WCCOActrl    (2), 2017.02.21 13:37:31.339, SYS,  INFO,        4, Connected to (SYS: 1 Event -num 0 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILevent   (0), 2017.02.21 13:37:31.339, SYS,  WARNING,   105, Invalid license, Demo license found, Running as demo version, ctrl
WCCILevent   (0), 2017.02.21 13:37:31.355, SYS,  INFO,        4, Connected to (SYS: 1 Ctrl -num 2 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCOActrl    (1), 2017.02.21 13:37:31.355, CTRL, INFO,        0, , DB Version Update, 3.15 DB version 1, nothing to do
WCCOActrl    (2), 2017.02.21 13:37:31.370, SYS,  INFO,      102, Waiting for user names/passwords
WCCOActrl    (2), 2017.02.21 13:37:31.370, SYS,  INFO,      103, User names/passwords initialized
WCCILpmon    (1), 2017.02.21 13:37:31.448, SYS,  INFO,        1, Manager Start, D:\\Siemens\\Automation\\WinCC_OA\\3.15\\bin\\WCCOActrl.exe -PROJ DemoApplication_3.15 -pmonIndex 13 scheduler.ctc
WCCOActrl    (0), 2017.02.21 13:37:31.511, SYS,  INFO,        1, Manager Start, PROJ, DemoApplication_3.15, V 3.15 - 3.15   platform Windows AMD64 linked at Jan 15 2017 22:10:59
WCCOActrl    (0), 2017.02.21 13:37:31.526, SYS,  INFO,        3, Trying to connect to (SYS: 0 Data -num 0 CONN: 1) @ localhost:4897
WCCOActrl    (0), 2017.02.21 13:37:31.526, SYS,  INFO,        4, Connected to (SYS: 0 Data -num 0 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:31.542, SYS,  INFO,        4, Connected to (SYS: 1 Ctrl -num 3 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:31.558, SYS,  INFO,        0, , Manager (SYS: 1 Ctrl -num 3 CONN: 1) initialised
WCCOActrl    (3), 2017.02.21 13:37:31.558, SYS,  INFO,        6, Initialization by Data Manager finished
WCCOActrl    (3), 2017.02.21 13:37:31.558, SYS,  INFO,        3, Trying to connect to (SYS: 1 Event -num 0 CONN: 1) @ localhost:4998
WCCOActrl    (3), 2017.02.21 13:37:31.573, SYS,  INFO,        4, Connected to (SYS: 1 Event -num 0 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILevent   (0), 2017.02.21 13:37:31.573, SYS,  WARNING,   105, Invalid license, Demo license found, Running as demo version, ctrl
WCCILevent   (0), 2017.02.21 13:37:31.589, SYS,  INFO,        4, Connected to (SYS: 1 Ctrl -num 3 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCOActrl    (3), 2017.02.21 13:37:31.589, SYS,  INFO,      102, Waiting for user names/passwords
WCCOActrl    (3), 2017.02.21 13:37:31.604, SYS,  INFO,      103, User names/passwords initialized
WCCILpmon    (1), 2017.02.21 13:37:31.682, SYS,  INFO,        1, Manager Start, D:\\Siemens\\Automation\\WinCC_OA\\3.15\\bin\\WCCOActrl.exe -PROJ DemoApplication_3.15 -pmonIndex 14 webclient_http.ctl
WCCOActrl    (0), 2017.02.21 13:37:31.776, SYS,  INFO,        1, Manager Start, PROJ, DemoApplication_3.15, V 3.15 - 3.15   platform Windows AMD64 linked at Jan 15 2017 22:10:59
WCCOActrl    (0), 2017.02.21 13:37:31.792, SYS,  INFO,        3, Trying to connect to (SYS: 0 Data -num 0 CONN: 1) @ localhost:4897
WCCOActrl    (0), 2017.02.21 13:37:31.792, SYS,  INFO,        4, Connected to (SYS: 0 Data -num 0 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:31.807, SYS,  INFO,        4, Connected to (SYS: 1 Ctrl -num 4 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:31.823, SYS,  INFO,        0, , Manager (SYS: 1 Ctrl -num 4 CONN: 1) initialised
WCCOActrl    (4), 2017.02.21 13:37:31.823, SYS,  INFO,        6, Initialization by Data Manager finished
WCCOActrl    (4), 2017.02.21 13:37:31.838, SYS,  INFO,        3, Trying to connect to (SYS: 1 Event -num 0 CONN: 1) @ localhost:4998
WCCOActrl    (4), 2017.02.21 13:37:31.838, SYS,  INFO,        4, Connected to (SYS: 1 Event -num 0 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILevent   (0), 2017.02.21 13:37:31.854, SYS,  WARNING,   105, Invalid license, Demo license found, Running as demo version, ctrl
WCCILevent   (0), 2017.02.21 13:37:31.854, SYS,  INFO,        4, Connected to (SYS: 1 Ctrl -num 4 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCOActrl    (4), 2017.02.21 13:37:31.870, SYS,  INFO,      102, Waiting for user names/passwords
WCCOActrl    (4), 2017.02.21 13:37:31.870, SYS,  INFO,      103, User names/passwords initialized
WCCILpmon    (1), 2017.02.21 13:37:31.916, SYS,  INFO,        1, Manager Start, D:\\Siemens\\Automation\\WinCC_OA\\3.15\\bin\\WCCOApid.exe -PROJ DemoApplication_3.15 -pmonIndex 15
WCCOApid     (1), 2017.02.21 13:37:31.979, SYS,  INFO,        1, Manager Start, PROJ, DemoApplication_3.15, V 3.15 - 3.15   platform Windows AMD64 linked at Jan 15 2017 22:10:59
WCCOApid     (1), 2017.02.21 13:37:31.979, SYS,  INFO,        3, Trying to connect to (SYS: 0 Data -num 0 CONN: 1) @ localhost:4897
WCCOApid     (1), 2017.02.21 13:37:31.994, SYS,  INFO,        4, Connected to (SYS: 0 Data -num 0 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:31.994, SYS,  INFO,        4, Connected to (SYS: 1 Api -num 1 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:32.010, SYS,  INFO,        0, , Manager (SYS: 1 Api -num 1 CONN: 1) initialised
WCCOApid     (1), 2017.02.21 13:37:32.026, SYS,  INFO,        6, Initialization by Data Manager finished
WCCOApid     (1), 2017.02.21 13:37:32.026, SYS,  INFO,        3, Trying to connect to (SYS: 1 Event -num 0 CONN: 1) @ localhost:4998
WCCOApid     (1), 2017.02.21 13:37:32.026, SYS,  INFO,        4, Connected to (SYS: 1 Event -num 0 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILevent   (0), 2017.02.21 13:37:32.041, SYS,  WARNING,   105, Invalid license, Demo license found, Running as demo version, api
WCCILevent   (0), 2017.02.21 13:37:32.041, SYS,  INFO,        4, Connected to (SYS: 1 Api -num 1 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCOApid     (1), 2017.02.21 13:37:32.057, SYS,  INFO,      102, Waiting for user names/passwords
WCCOApid     (1), 2017.02.21 13:37:32.057, SYS,  INFO,      103, User names/passwords initialized
WCCILpmon    (1), 2017.02.21 13:37:32.150, SYS,  INFO,        1, Manager Start, D:\\Siemens\\Automation\\WinCC_OA\\3.15\\bin\\WCCOAui.exe -PROJ DemoApplication_3.15 -pmonIndex 17 -m vision:WinCC_OA,393x172+315+298 -p vision/login.pnl -extend -iconBar -menuBar
WCCOAui      (0), 2017.02.21 13:37:32.634, SYS,  INFO,        1, Manager Start, PROJ, DemoApplication_3.15, V 3.15 - 3.15   platform Windows AMD64 linked at Jan 15 2017 22:10:59
WCCOAui      (0), 2017.02.21 13:37:32.650, SYS,  INFO,        3, Trying to connect to (SYS: 0 Data -num 0 CONN: 1) @ localhost:4897
WCCOAui      (0), 2017.02.21 13:37:32.651, SYS,  INFO,        4, Connected to (SYS: 0 Data -num 0 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:32.651, SYS,  INFO,        4, Connected to (SYS: 1 Ui -num 1 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILdata    (0), 2017.02.21 13:37:32.664, SYS,  INFO,        0, , Manager (SYS: 1 Ui -num 1 CONN: 1) initialised
WCCOAui      (1), 2017.02.21 13:37:32.670, SYS,  INFO,        6, Initialization by Data Manager finished
WCCOAui      (1), 2017.02.21 13:37:32.676, SYS,  INFO,        3, Trying to connect to (SYS: 1 Event -num 0 CONN: 1) @ localhost:4998
WCCOAui      (1), 2017.02.21 13:37:32.698, SYS,  INFO,        4, Connected to (SYS: 1 Event -num 0 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCILevent   (0), 2017.02.21 13:37:32.706, SYS,  WARNING,   105, Invalid license, Demo license found, Running as demo version, ui
WCCILevent   (0), 2017.02.21 13:37:32.713, SYS,  INFO,        4, Connected to (SYS: 1 Ui -num 1 CONN: 1) @ MD1KH1GC.ad001.siemens.net (127.0.0.1)
WCCOAui      (1), 2017.02.21 13:37:32.721, SYS,  INFO,      102, Waiting for user names/passwords
WCCOAui      (1), 2017.02.21 13:37:32.727, SYS,  INFO,      103, User names/passwords initialized
WCCILpmon    (1), 2017.02.21 13:37:32.737, SYS,  INFO,        9/pmon, The project is up and running. Entering monitor mode
WCCOActrl    (4), 2017.02.21 13:37:33.174, CTRL, SEVERE,      5/ctrl, Location of the following log entry: webclient_http.ctl    Line: 59
WCCOActrl    (4), 2017.02.21 13:37:33.174, SYS,  SEVERE,      1/http, The Port 443 could not be opened.
WCCOActrl    (4), 2017.02.21 13:37:33.191, CTRL, WARNING,    54, Unexpected state, httpServer could not be started
WCCOAui      (1), 2017.02.21 13:37:42.973, SYS,  INFO,      181, Closing connection to (SYS: 1 Data -num 0 CONN: 1)
WCCOAui      (1), 2017.02.21 13:37:42.996, SYS,  INFO,      181, Closing connection to (SYS: 1 Event -num 0 CONN: 1)
WCCILdata    (0), 2017.02.21 13:37:42.996, SYS,  INFO,       39, Connection lost, MAN: (SYS: 1 Ui -num 1 CONN: 1), Connection closed
WCCOAui      (1), 2017.02.21 13:37:43.013, SYS,  INFO,       39, Connection lost, MAN: (SYS: 1 Data -num 0 CONN: 1), Connection closed
WCCILevent   (0), 2017.02.21 13:37:43.011, SYS,  INFO,       39, Connection lost, MAN: (SYS: 1 Ui -num 1 CONN: 1), Connection closed
WCCOAui      (1), 2017.02.21 13:37:43.023, SYS,  INFO,       39, Connection lost, MAN: (SYS: 1 Event -num 0 CONN: 1), Connection closed
WCCOAui      (1), 2017.02.21 13:37:43.078, SYS,  INFO,        2, Manager Stop
Denis Pregnolato wrote:
To get the listening ports you should use the '-a' option of netstat. HTTP uses TCP connections, so UDP is not required.
MrKintaro
Post by MrKintaro »
agruber
Post by agruber »
Something seems to listen to port 443, it can be seen in the screenshot above.
It seems that port 444 is free, try to change the config entries:
[webClient]
httpPort = 81
httpsPort = 444
And afterwards set the port accordingly in the project view of the desktop UI
