SNMP manager does not receive traps
vedadramovic
Post by vedadramovic »
I have configured on a windows test platform WinCCOOA project Version V3.14 with SNMP manager.
It receives SNMP traps in internal datapoint normally.
When the same project configuration is applied on linux platform, SNMP traps are not written in internal data point.
SNMP agent is the same in both cases, and SNMP traps are received on linux computer (they are trapped by tcpdump).
Here is log from linux based SNMP manager
WCCOAsnmp16:WCCOAsnmp (16), 2017.02.01 12:45:14.485, DRV_WORK, DrvAlive::timerExpired sec:40 usec: 0
WCCOAsnmp16:WCCOAsnmp (16), 2017.02.01 12:45:14.485, API_USR1, Agent 0/1 added request: "TIMEOUTMONITOR"
WCCOAsnmp16:WCCOAsnmp (16), 2017.02.01 12:45:14.486, EV_WORK, Agent 0/1 handling request for 1.3.6.1.2.1.1.1.0
WCCOAsnmp16:OID 1.3.6.1.2.1.1.1.0, value
WCCOAsnmp16:WCCOAsnmp (16), 2017.02.01 12:45:14.486, DRV_USR1, Agent 0/1 GET request for "TIMEOUTMONITOR"
WCCOAsnmp16:WCCOAsnmp (16), 2017.02.01 12:45:16.491, API_USR1, callback status -5 reason -5 pdu status 0
WCCOAsnmp16:WCCOAsnmp (16), 2017.02.01 12:45:34.227-- Msg overview elapsed secs since last report: 30.001
WCCOAsnmp16: snd total: 619 rcv total: 612
WCCOAsnmp16: snd since last: 0 rcv since last: 0
WCCOAsnmp16:-- Msg details
WCCOAsnmp16:man S/R msg -
WCCOAsnmp16:-----------------------------------
WCCOAsnmp16:WCCOAsnmp (16), 2017.02.01 12:45:56.492, DRV_WORK, DrvAlive::timerExpired sec:40 usec: 0
WCCOAsnmp16:WCCOAsnmp (16), 2017.02.01 12:45:56.492, API_USR1, Agent 0/1 added request: "TIMEOUTMONITOR"
WCCOAsnmp16:WCCOAsnmp (16), 2017.02.01 12:45:56.493, EV_WORK, Agent 0/1 handling request for 1.3.6.1.2.1.1.1.0
WCCOAsnmp16:WCCOAsnmp (16), 2017.02.01 12:45:56.493, DRV_USR1, Agent 0/1 GET request for "TIMEOUTMONITOR"
WCCOAsnmp16:WCCOAsnmp (16), 2017.02.01 12:45:58.501, API_USR1, callback status -5 reason -5 pdu status 0
WCCOAsnmp16:WCCOAsnmp (16), 2017.02.01 12:46:04.227-- Msg overview elapsed secs since last report: 30
below is a log from windows based SNMP manager
WCCOAsnmp15:WCCOAsnmp (15), 2017.02.01 12:45:38.034, API_USR3, Got trap from 192.168.131.242
WCCOAsnmp15:WCCOAsnmp (15), 2017.02.01 12:45:38.035, OUTPUTREADY, (SYS: 1 Event -num 0 CONN: 1) @ BST114.bstelecom.ba: sendCall. 788B pending in 1 buffers.
WCCOAsnmp15:WCCOAsnmp (15), 2017.02.01 12:45:38.035, DRV_USR2, getAgent: Starting compare with 192.168.131.242 no. of agents 1
WCCOAsnmp15:WCCOAsnmp (15), 2017.02.01 12:45:38.035, DRV_USR2, notifyTrap for agent 1
WCCOAsnmp15:02.01 12:45 1_1.3.6.1.4.1.24149.1.2.1.0.10_0 "" >>
WCCOAsnmp15:SANORS: "" varID 0 phantom 0
WCCOAsnmp15:PA ""
WCCOAsnmp15:MapObj: Time: --NO_TIMEPRINT--
WCCOAsnmp15:0#"" 0 [l=0] >>
WCCOAsnmp15:" "
WCCOAsnmp15:02.01 12:45 1_1.3.6.1.4.1.24149.1.2.4.1.1_0 "" >>
WCCOAsnmp15:PA ""
WCCOAsnmp15:" "
WCCOAsnmp15:WCCOAsnmp (15), 2017.02.01 12:45:38.036, DRV_USR2, sending trap id to address "1_1.3.6.1.4.1.24149.1.2.4.1.1" oid 1.3.6.1.4.1.24149.1.2.4.1.1, value 0
WCCOAsnmp15:WCCOAsnmp (15), 2017.02.01 12:45:38.036, WORK, "processData2Dp called: startix = 0; nofElements = 1 at 2017.02.01 12:45:38.036"
WCCOAsnmp15:WCCOAsnmp (15), 2017.02.01 12:45:38.036, DISPATCH, "starting convert2Ing ,0 at 2017.02.01 12:45:38.036"
WCCOAsnmp15:WCCOAsnmp (15), 2017.02.01 12:45:38.037, WORK, "convert2Ing called for (Type: 211 Sys: 1 Dp: 464 El: 5 : _address..)"
WCCOAsnmp15:WCCOAsnmp (15), 2017.02.01 12:45:38.037, DISPATCH, "convert2Ing ready ,0" at "2017.02.01 12:45:38.037"
WCCOAsnmp15:02.01 12:45 1_1.3.6.1.4.1.24149.1.2.2_0 "" >>
WCCOAsnmp15:PA ""
WCCOAsnmp15:0#"" 0 [l=3] >>
WCCOAsnmp15:" "
WCCOAsnmp15:WCCOAsnmp (15), 2017.02.01 12:45:38.038, DRV_USR2, sending trap id to address "1_1.3.6.1.4.1.24149.1.2.2" oid 1.3.6.1.4.1.24149.1.2.2, value Source type: Device; Source name: Camera 1
WCCOAsnmp15:WCCOAsnmp (15), 2017.02.01 12:45:38.038, WORK, "processData2Dp called: startix = 0; nofElements = 1 at 2017.02.01 12:45:38.038"
WCCOAsnmp15:WCCOAsnmp (15), 2017.02.01 12:45:38.038, DISPATCH, "starting convert2Ing ,0 at 2017.02.01 12:45:38.038"
WCCOAsnmp15:WCCOAsnmp (15), 2017.02.01 12:45:38.039, WORK, "convert2Ing called for (Type: 211 Sys: 1 Dp: 464 El: 6 : _address..)"
WCCOAsnmp15:WCCOAsnmp (15), 2017.02.01 12:45:38.039, DISPATCH, "convert2Ing ready ,0" at "2017.02.01 12:45:38.039"
WCCOAsnmp15:WCCOAsnmp (15), 2017.02.01 12:45:38.039, DRV_TEST_DATAACCESS_INPUT, Sending VC message(s) with 2 items to EV.
WCCOAsnmp15:WCCOAsnmp (15), 2017.02.01 12:45:38.039, WORK, Now sending message(s) with 2 items.
WCCOAsnmp15:WCCOAsnmp (15), 2017.02.01 12:45:38.039, OUTPUTREADY, (SYS: 1 Event -num 0 CONN: 1) @ BST114.bstelecom.ba: sendCall. 1kB pending in 1 buffers.
WCCOAsnmp15:WCCOAsnmp (15), 2017.02.01 12:45:38.039, DBG, "WCCOAsnmp (15), 2017.02.01 12:45:38.039#= 1 Messages 1485949538,39 (2 ValueChanges)"
WCCOAsnmp15:WCCOAsnmp (15), 2017.02.01 12:45:38.040, QUERY, Msg sent at 2017.02.01 12:45:38.040
WCCOAsnmp15:WCCOAsnmp (15), 2017.02.01 12:45:38.040, OUTPUTREADY, (SYS: 1 Event -num 0 CONN: 1) @ BST114.bstelecom.ba: outputReady
WCCOAsnmp15:WCCOAsnmp (15), 2017.02.01 12:45:38.040, OUTPUTREADY, (SYS: 1 Event -num 0 CONN: 1) @ BST114.bstelecom.ba: Starting new buffer with 1048 bytes
WCCOAsnmp15:WCCOAsnmp (15), 2017.02.01 12:45:38.040, OUTPUTREADY, (SYS: 1 Event -num 0 CONN: 1) @ BST114.bstelecom.ba: 1056 bytes sent
WCCOAsnmp15:WCCOAsnmp (15), 2017.02.01 12:45:38.040, OUTPUTREADY, (SYS: 1 Event -num 0 CONN: 1) @ BST114.bstelecom.ba: All transmitted
Can you help me?
agruber
Re: SNMP manager does not receive traps
Post by agruber »
as far as I know you cannot simply bind privileged ports (
vedadramovic
you are right, default SNMP trap port 162 is privileged port on linux.
After transfering SNMP trap port to higher value it is working fine on linux.
Thank you very much Andreas.
