Information provided in Dialog in edit mode should be saved in ewo during run mode.
Pradeep Kumar
Post by Pradeep Kumar »
Through extended properties we have a dilaog to change the value , which should get reflected in ewo in run mode. in edit mode the value is getting reflected .
But once we save the value in dialog and run the panel, the value is not getting reflected in ewo.
Re: Information provided in Dialog in edit mode should be saved in ewo during run mode.
Could you clarify your issue more? For me it is not clear what you have done.
