Re: How can i get all datapoints with an achive config
Postby leoknipp »
Getting the information for the _archive config with a dpQuery() is not possible. A dpQuery() is answered by the event manager and the information for the _archive configs is only known in the data manager.
Therefore doing a dpConnect() for the _archive config is also not possible.
If you are using the value archives (HDB) you can get the information for the archived dp elements using the Statistics function for the archives.
Another possibility would be to make an ASCII export for the _archive config and to parse the file.
Why do you want to know which elements have an _archive config?
Why shall a connect be made for this config?
Postby pke-smx »
Ahhh ok
We do not use the common wincc oa archives.
We have our own archiving. And therefore we just want to use the _archive.._type Attribute.
If the _archive.._type is not null write the datapoint value into our mysql database.
Postby leoknipp »
In this case you could use another config, e.g. the _general config to store the information which elements need to archived.
The _general config can be used at queries.
Postby RudiKreiner »
I guess you are right on that. I just checked the description of dpConnect() in WinCC OA help, and it says that it is only possible to connect to configs that are managed by the event manager, which excludes the following: _archive, _address, _cmd_conv, _msg_conv, _smooth
It should work for the general config though, so I think you are on the right track. Good luck with that.
