S7+ driver in 3.15 final does not start with an error message about license.
1 post • Page 1 of 1
agruber
Post by agruber »
Unfortunately on some Windows machines the S7+ driver does not start correctly with the final version of WinCC OA 3.15.
The message looks like:
S7PlusHWService, licensing, Cannot validate S7DOS licensing, error 158. Consider reinstallation!
There is a relatively simple fix for this, simply download the attached ZIP file and start the extracted executable on your machine. It makes necessary changes to the configuration of the S7DOS library. The error message should be gone after running the tool. You can use this for your existing installation.
A similar change was also applied to the setup for future installations. So if you download the setup again, it will already contain the change and the S7+ driver will work from the beginning. The new setup has the MD5 hash: 831585f9cf85edbf4e7d88ded25c89a2 .
BR,
Andreas Gruber
Head of Customer Care https://www.winccoa.com/fileadmin/image ... S7plus.zip
fixS7plus.zip
(8.78 KiB) Downloaded 283 times
