We have windows 7,8 and 10. we have compiled Qt code in Win 7, able to load ewo in WinCC OA without any problem,
but in Win 10 the same code , when we compile and provide the ewo for WinCC OA,
we are getting error has EWO could not be loaded.
The EWO "C:\\Siemens\\Automation\\WinCC_OA\\3.15\\bin\\widgets/windows-64/TestingWin10.ewo" is version "1", but we can only load version "4"
Any specific reason are we missing anything?
The source code compilation for all versions
- Pradeep Kumar
- agruber
Re: The source code compilation for all versions
Typically this error message appears if the EWO cannot be loaded correctly. Eventually your EWO uses a dependency which does not exist in Windows 10. Normally a seperate compile for Windows 10 is not necessary.
With dependency walker you can check which dependencies the EWO has and which cannot be found.
