First I'm new to WinCC OA.
I want to know if it's possible to connect wincc OA to Java, so I can read/set values etc..
If its possible how I can do it?
Connect WinnCC OA to Java
- vogler
Re: Connect WinnCC OA to Java
There is no official Java API for WinCC OA.
Once a time I built a Java API:
http://www.winccoa.at/wordpress/?p=722
(there is a download link, but it is an old version)
With that you can implement a Java program which connects to WinCC OA directly & natively - the WinCC OA native (C++) libs are used in Java by JNI.
Another option would be to exchange information by coupling Java and OA loosely - e.g. by Webservices, Http/JSON or XMLRPC... it depends on your business needs...
- fmulder
I believe that 3.15 will introduce the option to integrate java widgets in the UI. We've seen demos of it on the previous user day.
The other option is to implement a C++ controll DLL and implement some kind of tcp/ip based protocol.
- vogler
regarding "widgets in the UI" - this is JavaScript - not Java!
- joao.matos
Thank you very much for the replies.
@Andreas Vogler: I would like to try using the Java API that you mentioned. However, since as you said it is an old version, is there an updated one that I could use, or should I just stick with that one?
- vogler
I think I will not find time to package an update (in next days). Give that version a try, if you have questions or if you need help, send me an eMail: andreas.vogler@etm.at
- CyaNn
Hello Andrea,
Writing a driver in Java is a great stuff.
Do you plan to make your library, officially supported by WinCC ? Ans why not packaged with it ?
I am really interested by this feature. Actually I am writing my drivers and other extensions in C++ and have to face a lots of compatibility issues between Win & Linux. At Skyguide, we also planned to connect WinCC to SOA based ESB for monitoring stuffs. It should be awesome to doing it directly from Java.
Many thanks in advance for your answer.
Yann
Yann
