I have a problem upgrading a project from Version 3.9 to 3.14.
I get the following error message that the version 3.9 is too old for an automatic update and that I should perform a manual update.
I did not found anything in the documentation about versions being too old for an automatic update and also no information about how an manual update would be performed.
Error message:
"WCCOAui (0), 2017.01.12 13:29:48.679, PARAM,INFO, 11/pv2admin, The project D:\\Projects\\XXX has a too old version 3.9 and can not be updated automatically. Manual update is needed."
Any help to solve this problem and get my project upgraded is appreciated.
Upgrade 3.9 > 3.14
Re: Upgrade 3.9 > 3.14
please check if there is a "source" directory existing in your WinCC OA project.
If it does not exist please create it and try to upgrade the project again.
- dbindernagel
The source folder was indeed missing and the problem.
The upgrade process started without errors once I created the folder.
Thanks a lot for the quick response.
