Where can I donwload WinCC OA old versions?
yosu
Post by yosu »
I need to convert an old project from WinCC OA 3.11. I am trying to download version 3.11 for Linux but on downloads section, the oldest version I can find, is 3.12. Where can I download WinCC OA older versions?
Re: Where can I download WinCC OA old versions?
On the ETM Portal only the officially supported versions are available for the download. See the older topics.
Re: Where can I donwload WinCC OA old versions?
if you want to convert an old project to a newer version there is no need to install the old version.
You just have to install the new version including the option "old version support". This option can be selected during the setup process.
In the project administration you can register the project and make the upgrade.
yosu
Post by yosu »
I register project, try to upgrade and error occur:
convertDb:WCCILdata    (0), 2017.03.22 15:31:05.377: "3.11" does not match with manager version: "3.14" !!
convertDb:WCCILdata    (0), 2017.03.22 15:31:05.381, PARAM,FATAL,      54, Unexpected state, main, Data manager does not run on data host
No problem to upgrade another project 3.12. I have installed WinCC OA 3.12 and WinCC OA 3.14
It looks like you have defined dataHost/eventHost or data/event entries in the config file of the project and the hostnames do not fit the hostname where you have tried to upgrade the project.
Please check the settings in the config file and start the upgrade again using a complete backup of the original project.
If the upgrade process was stopped in between the project database is in an undefined state and therefore you have to use the original project.
yosu
Post by yosu »
Yes! You are right. Config file project has:
data = "10.xxx.xxx.xxx"
event = "10.xxx.xxx.xxx"
Comment it and solved.
