Monitor a computer by using IP Address
cofelyhoogland
Post by cofelyhoogland »
Can anyone tell me how I can monitor a computer using IP Address. Normally i use SNMP address for monitoring but now i have only the IP Address.
someone with a great idea.
agruber
Re: Monitor a computer by using IP Address
Post by agruber »
You can easily do that with a system call and the ping command. Be aware, if the router returns "host unreachable", the error code of ping is 0 (=OK), so you need to check the output of the ping command too.
See example below.
BR,
Customer Care
bool checkPingWithTTL(string ip)
  bool ret = false;
  string sout = "";
  int irc = 0;
  irc = system("ping -n 1 " + ip, sout);
  // error code is 0 if host is unreachable, so check for output if TTL
  if (irc == 0 && strpos(sout, "TTL=") >= 0 )
    ret = true;
  return ret;
Just enable and configure the snmp service/daemon. Then you can also use snmp for monitoring. See also this topic: use SNMP to monitor Windows computers.
