How to use VLC ActiveX inside WINCC OA 3.14
7 posts • Page 1 of 1
ubusto
Post by ubusto »
I have installed the VLC-2.2.4 64bits package in a enviroment with WinCCOA 3.14
When i look for the ActiveX it apperas with the name "VLC ActiveX Plugin and IE Web Plugin v2"
I put it on the panel and it displays:
Error
VideoLAN.VLCPlugin.2
could not be loaded
Could someone please tell me how to display an ip camera stream using VLC within WINCC OA 3.14
Re: How to use VLC ActiveX inside WINCC OA 3.14
Maybe you can use our WebView.ewo in combination with this: https://kanaka.github.io/noVNC/
ubusto
Post by ubusto »
Thx Martin,
I will check it out, but it seems i need to set up some kind of server, and what i need is to show directly the ip camera in a winccoa 3.14 panel.
Another possibility would be to create a new VNC ewo based on this Qt sources: https://bitbucket.org/amahta/qvncclient/src
ubusto
Post by ubusto »
Thx Martin,
So in your opinion it's not possible to stream directly using the VLC ActiveX?
Can't tell you what's wrong with your active x. Since I'm on Linux only, I can't test easily.
Please get in contact with our support.
I've tested it and inserted the ActiveX into a panel.
There was no error reported.
