Regarding the Qt version to be used for WinCC OA
8 posts • Page 1 of 1
Pradeep Kumar
Post by Pradeep Kumar »
As per the documentation we need to use Qt 5.5.0 with visual studio compiler ,
as we 5.6 and 5.7 version also , why cant we use latest Qt version,
why specifically Qt 5.5.0 we need to use?
Re: Regarding the Qt version to be used for WinCC OA
We deliver Qt 5.5 so during runtime, when your ewo is loaded, there is only Qt 5.5 available.
Pradeep Kumar
Qt 5.5.0 32 bit or 64 bit should work, we are using Qt 5.5.0 32 bit with visual studio 2013 .
will the version of Qt also depend?
I do not understand the question.
Pradeep Kumar
Do we need Qt 5.5.0 64 bit for WinCC OA?.
In WinCC OA docs they didnt mention about Qt bit version?.
This was my question
You need to use the same bit-version as the WinCC_OA product uses, which is normally 64bit.
Since an EWO is a plugin (dll on windows) the number of bits must match with the application (UI Manager) which loads the plugin.
Pradeep Kumar
in the below link i downloaded qt
https://download.qt.io/archive/qt/5.5/5.5.0/
i downloaded qt-opensource-windows-x86-msvc2013_64-5.5.0.exe
it is showing 32 bit.
That is a 64 bit package. Where does it show 32 bit?
