Error in AES.Ctl
mustafa.toker@siemens.com
Error in AES.Ctl
Post by mustafa.toker@siemens.com »
We are receiving the warning herebelow and we could not find a solution for it. :blink:
The project is redundant distributed if it helps and that's it as I guess.
PVSS00ui (8), 2011.11.24 18:17:18.014, CTRL, WARNING, 76, Invalid argument in function,
Module: infoModule_1
Panel: C:\\ETM\\PVSS2\\3.9\\panels\\para\\PanelTopology\\templates\\TEMPLATE2\\infoPanel_1024_768_TEMPLATE2.pnl []
Object: 1 named: "table_top" of type: TABLE
In reference: vision\\aes\\AESRow.pnl Group: 19 named: ""
Script: Initialize
Library: C:\\ETM\\PVSS2\\3.9\\scripts\\libs\\aes.ctl
Line: 13031, dpQueryDisconnect, 1_0_1_1_FALSE_infoModule_1
Mustafa
Re: Error in AES.Ctl
the log-message describes that the dpQueryDisconnect-function was not working properly.
To find the cause for it we need detailled information.
Please send an e-mail to the official support address support.automation@siemens.com.
You'll then receive an answer with details how the cause can be found or which information is needed for the analysis.
My collague will provide the necessary info and create and entry to support.
BR, Mustafa
