While communication with wincc OA to control logix through Ethernet driver communication not establish.
pls share possible check list for troubleshooting.
communication problem
- alug
Re: communication problem
do you have a peripheral address parameterized on a DPE which refers to the EIP connection?
This is necessary that the driver uses the parameterized EIP connection.
Is there an error message written by the driver during connection establishment?
- saurabhltts
yes already create parameterized on a DPE and link with that still when generate query it shows not connected.
please help me on that.
- alug
Look in the LogViewer if you get any error message from the driver (WCCOAeip).
You can also look in your project log/PVSS_II.log file.
If you see messages ".. sendRequest, Timeout expired for connection ..."
than you have a connection problem.
In that case check your IP address in EIP PLC configuration panel.
Try to "ping" the PLC address to check if IP connection is possible.
If you do not see any error message from the driver and you do not get
connected than check if your peripheral address has correct driver
number configured.
number configured.
- saurabhltts
I get ping from device, as well as driver I used for control logix is EIP over there its IP setting and other detail I varefiy once again.
I follow below step pls confirm any step pending
1) I create EIP driver with all detail. like pls type, ip address, slot no.
2) link up with DPE tag.
- alug
Do you get the error message as I mentioned above?
- saurabhltts
yes
Error msg : FATAL : 5 : connection not possible WCCILdata
FATAL : 63 : Connection error, this manager is already connected or data is running in emergency /backup
Also EIP manager not in run flashing yellow and blue.
in that case it is not a problem for the connection between the driver and the PLC.
When the log message is written by the data manager a manager of the same type (UI; CTRL, driver, ...) with the same number is already running.
Please use a different manager number or stop the other manager (same type, same number) if it is not needed.
- saurabhltts
thank you now connection establish,
further I have 2 query request you to pls help me on that,
we have to create EIP driver configuration first and later EIP manager need to be add in wincc console ??
I need to append manager or insert new manager ??
object script wizard configuration change I m not able to map my DP to object property.
- saurabhltts
kindly see script wizard scree shot for more clarification
