communication problem
14 posts • Page 2 of 2
saurabhltts
Re: communication problem
Post by saurabhltts »
While creating second time this
WCCOAeip , IMPL, FATAL, 5, Connection not possible, WCCILdata
WCCOAui SYS, WARNING, 54, Unexpected state, Qt, QWindowsWindow::setGeometryDp: Unable to set geometry 1280x961+8+31 on QWidgetWindow/'QMainWindowClassWindow'. Resulting geometry: 1276x961+8+31 (frame: 8, 31, 8, 8, custom margin: 0, 0, 0, 0, minimum size: 69x124, maximum size: 16777215x16777215).
the log message for the EIP driver you have copied does not show any information why the connection to the data manager is not possible.
The other log message is written by the user interface and is not related to the EIP driver.
It does not make difference if you add a new manager at the end of the list or if it is added in between.
The only thing you have to take into account is that the data- and event-manager need to be started before a driver is started, otherwise the connection cannot be established.
The screenshot for the wizard cannot be seen.
saurabhltts
thanks for your detail reply further while running project below error message shown and EIP manager stop.
I also ensure each driver having different number.
WCCOAeip (1), 2016.11.24 09:25:04.795, SYS, SEVERE, 229, The Manager (SYS: 0 Driver -num 1 CONN: 1) is already running at host localhost., MAN: (SYS: 1 Data -num 0 CONN: 1)
WCCILdata (0), 2016.11.24 09:25:04.795, SYS, SEVERE, 229, The Manager (SYS: 0 Driver -num 1 CONN: 1) is already running at host localhost.
WCCOAeip (1), 2016.11.24 09:25:04.796, SYS, INFO, 39, Connection lost, MAN: (SYS: 0 Data -num 0 CONN: 1), Connection closed
WCCOAeip (1), 2016.11.24 09:25:04.796, IMPL, FATAL, 5, Connection not possible, WCCILdata
WCCOAui (2), 2016.11.24 09:25:05.066, SYS, WARNING, 54, Unexpected state, Qt, QWindowsWindow::setGeometryDp: Unable to set geometry 1280x961+8+31 on QWidgetWindow/'QMainWindowClassWindow'. Resulting geometry: 1276x961+8+31 (frame: 8, 31, 8, 8, custom margin: 0, 0, 0, 0, minimum size: 69x124, maximum size: 16777215x16777215).
to be able to see why the process cannot be started we need to see the complete log file (pmon., PVSS_II.log) for the project startup.
Please copy these two files and get in contact with your common WinCC OA support.
