I have warning after upgrade to 3.14 - Qt, libpng warning: iCCP: known incorrect sRGB profile
yjsid939
Post by yjsid939 »
And after upgrade I have this error
WCCOAui (2), 2016.11.08 18:20:19.188, SYS, WARNING, 54, Unexpected state, Qt, libpng warning: iCCP: known incorrect sRGB profile
WCCOAui (2), 2016.11.08 18:20:19.208, CTRL, WARNING, 5/ctrl, Location of the following log entry:
All object which filled with pictures have same error.
I think png files which I have have imcompatible sRGB color profile so I tested with png file with RGB profile, in this case no warning.
But there are too many picture files to convert.
Please let me know how can I remove this problems.
Thank you
flindecke
Re: I have warning after upgrade to 3.14 - Qt, libpng warning: iCCP: known incorrect sRGB profile
Post by flindecke »
As long as i know it is a problem of the used library libpng which is used by Qt.
You can strip all of your ICC Profile from png files by using Imagequick.
See https://wiki.archlinux.org/index.php/Libpng_errors for a short description of the problem and the command for stripping the profile.
Hope this would help.
Andorhal
Post by Andorhal »
Hello.
Frank is completely right.
Pls have a look at our FAQ here.
It explains background and gives examples how to identify/resolve the issue.
Our own PNGs had to be modified as well but since you can do it for all images with a single command line the effort to do so is very small.
Robert
yjsid939
Post by yjsid939 »
Thank you everyone.
As you mentined, I converted all my images with IMAGEMAGIK.
And finally I removed all warnings.
Add one more tip.
To make batch job, I use dir *.png /b /s >> list.txt in command prompt windows.
then all png files list save to list.txt with path.
After that open list.txt and modify all lines like
mogrify "path1\\path2\\image.png" and save.
" is needed if path or file name include space then mogrify can't recognize whole infomaton.
After that rename list.txt -> conv.bat
and run this batch file in command window.
You can converting status ~~
Don't forget to backup your images before converting.
Thank you and have a nice day!
On Linux one would do:
find . -name \\*.png -print0 | xargs -0 mogrify
That recursively - starting from "." (current dir) - changes all files even those with blanks.
