AGorbatykh
Posts: 59 Joined: Thu Dec 17, 2015 1:01 pm
Hysteresis value.
Post
by AGorbatykh » Tue Nov 01, 2016 9:50 am
Hello.
I tried to set hysteresis to alert andler from script, like this:
dpSetWait( dp+".Value:_alert_hdl.4._u_hyst_limit",(float) (Val1 - hyst),
dp+".Value:_alert_hdl.3._u_hyst_limit", (float) (Val2 - hyst),
dp+".Value:_alert_hdl.2._u_hyst_limit", (float) (Val3 - hyst),
dp+".Value:_alert_hdl.1._u_hyst_limit", (float) (Val4 - hyst));
But I cannot set any float value, only integer. For example, when I use hyst = 1.8, I set 1, etc.
How can I set float values for hysteresis from script&
nmnogueira
Posts: 125 Joined: Thu May 05, 2011 12:59 pm
Re: Hysteresis value.
Post
by nmnogueira » Wed Nov 02, 2016 10:23 am
Please confirm that Val1, Val2, Val3, Val4 are of type float, or else hyst will be cast to int before performing the subtraction, and only afterwards to float.
Or you can try with:
dpSetWait( dp+".Value:_alert_hdl.4._u_hyst_limit", ( (float) Val1 - hyst),
dp+".Value:_alert_hdl.3._u_hyst_limit", ( (float) Val2 - hyst),
dp+".Value:_alert_hdl.2._u_hyst_limit", ( (float) Val3 - hyst),
dp+".Value:_alert_hdl.1._u_hyst_limit", ( (float) Val4 - hyst));
