Hi! I need to addressing a Double Command dp in IEC driver.
I don't know how can i configure the addressing for a Selection/Ejecute option.
I don't know what is the steps to send a selection and how can i see the selecction is correct and latet send the execution.
The type is 46, and the quality Information is 128 to activate Selection/Ejecute...i know...but i don't know the step by step to do the order correctly.
Can anyone help me?
Thanks!!
Configure Double Command in IEC driver
Re: Configure Double Command in IEC driver
The command qualifier can be set in an user byte (config entry 'connUserByteQ') or in a second dpe by using a special 'COT' address.
This and more information can be found in the online help -> Drivers -> IEC -> Quality identifier
- xavi.aran
Sorry, but the online help about IEC is very bad...there you can't find any good information about the communication IEC.
I have a simple question (send a command with selection is a basic feature of IEC) and it's impossible to know how can i resolve reading help....
Can anyone help me a bit more?
I do not have experience with this, so did you try this example from the online help:
config entry:
[iec]
connUserbyteQ = 1
config entry:
[iec]
connUserbyteQ = 1
// select
dpSet("command.:_original.._value", 1,
"command.:_original.._user_byte1", 0x80);
// execute
"command.:_original.._user_byte1", 0);- alug
Hallo,
unfortunately there is an error in the online help example.
The correct code is:
// select
dpSet("System1:command.:_original.._value", 1, "System1:command.:_original.._userbit8", 1);
//execute
dpSet("System1:command.:_original.._value", 1, "System1:command.:_original.._userbit8", 0);
because the S/E Bit is the highest bit in the quality byte and connUserByteQ = 1 means the userbits 1-8.
So with _userbit8 you can define if it is a Select or an Execute.
best regards
// select
//execute
best regards
