C# API
jeissonsierrac
C# API
Post by jeissonsierrac »
Hello
I´m trying to implement a third party software to WinCC OA using a API Manager or a Ctrl Extention, the problem is that this software only can programme in C#, ¿Is there anyway to implement it?
Thanks for your support
vogler
Re: C# API
Post by vogler »
As far as i know in version 3.15 there will be a C# API available! So that you can write OA Managers in C#.
regards,
Re: C# API
A .NET assembly can be used by C++(/CLI) code, so you can use it in a control extension.
To use a .NET assembly:
  • Include 'vcclr.h' and 'msclr\\marshal_cppstd.h'
  • Enable the 'Common Language Runtime' support for these source files
  • Optional: Implement 'AssemblyResolve' to find the assembly
