How to configure sum alerts
Piterskiy
Post by Piterskiy »
Hello I have some problem with sumalerts.
I try to make sum alerts invisible in AESRow. Can I do this? Maybe I can set priority to sum alert order in AESRow?
How can I change text in sum alerts (alert groups "tag" for google search =)? How can I set different text instead of "Sum alert" ?
Thank you in advance.
Re: How to configure sum alerts
with the filter settings for the AESRow/the AEScreen you can define if summary alerts shall be shown or not.
If you want to change for the alert you have to modify the configuration for the _alert_hdl config. Therefore please select the _alert_hdl config for the dp-element, deactivate the alert handling and set the new text.
Senior Support Specalist
Piterskiy
Post by Piterskiy »
Thanks. I solve it throw DB. I don't know why I couldn't open the properties window in alert row.
