Hello
I'm trying to add a Reference panel with the function AddSymbol, I send some parameters, for example the text that the Panel reference will show, then I need the size of this reference panel to add another panels consequently but when I m going to get the size with the getValue function, this return me the size of the default panel, For example i have a reference panel with a primitive text with "Default" value, I call this reference panel with AddSymbol() and I send the text "hello world" as a parameter to the primitive text to show it , I use getValue to get the size of the reference panel, it returns me the size of the value "Default" instead of the value of "hello world".
Add Symbol Problem
- fmulder
Re: Add Symbol Problem
I'd guess that the following is happening:
* Your'e doing addSymbol() passing it a dyn_string with dollar parameters
* The symbol becomes 'alive' and starts to execute iit scripts
* Your doing a getvalue( "", "size" ) even before the script has finished setting the value to 'Hello world'
Just for testing :try doing a delay(1) just after the addSymbol(). This would confirm my suspicion.
The problem could be that the script in the newly added symbol runs asynchronously to the script adding that symbol. What you could do is set the text from the script that does the addSymbol() (so do not pass as dollar code, but write the shape directly).
In addSymbol(0 you specify the name of the newly added shape. When your shape is called TESTSHAPE then you should be able to do:
dyn_int diSize;
setValue( "TESTSHAPE.MyTextField", "text", "Hello World' );
getValue( "TESTSHAPE.MyTextField", "size", diSize );
Good luck
share the fun
Frenk Mulder.
dyn_int diSize;
Good luck
share the fun
Frenk Mulder.
in this case you want to get the size of an object and not the size of a reference panel.
If the size of objects is changed dynamically you have to read the new size of the object after changing the size as Frenk Mulder has described.
This needs alsways taken into account and not only when using reference panels.
