This errors appear when I attempt to use the import by ASCII manager. What can be wrong?
WCCOAascii_log:WCCOAascii (0), 2016.10.14 17:12:21.932, SYS, INFO, 1, Manager Start, PROJ, ezbar_v2, V 3.12 - 3.12 platform Windows AMD64 linked at Nov 28 2013 15:01:31
WCCOAascii_log:WCCOAascii (0), 2016.10.14 17:12:21.933, SYS, INFO, 3, Trying to connect to, (SYS: 0 Data -num 0 CONN: 1) @ server:4897
WCCOAascii_log:WCCOAascii (0), 2016.10.14 17:12:21.935, SYS, INFO, 4, Connected to, (SYS: 0 Data -num 0 CONN: 1) @ server (127.0.0.1)
WCCOAascii_log:WCCOAascii (1), 2016.10.14 17:12:21.948, SYS, INFO, 6, Initialization by Data Manager finished
WCCOAascii_log:WCCOAascii (1), 2016.10.14 17:12:21.948, SYS, INFO, 3, Trying to connect to, (SYS: 1 Event -num 0 CONN: 1) @ server:4998
WCCOAascii_log:WCCOAascii (1), 2016.10.14 17:12:21.949, SYS, INFO, 4, Connected to, (SYS: 1 Event -num 0 CONN: 1) @ server (127.0.0.1)
WCCOAascii_log:WCCOAascii (1), 2016.10.14 17:12:21.959, SYS, INFO, 102, Waiting for user names/passwords
WCCOAascii_log:WCCOAascii (1), 2016.10.14 17:12:21.959, SYS, INFO, 103, User names/passwords initialized
WCCILdatabg (1), 2016.10.14 17:12:22.297, IMPL, SEVERE, 54, Unexpected state, AlertDirDb, removeDb, nicht ausfuehrbar *** Code : 16
WCCILdatabg (1), 2016.10.14 17:12:22.311, IMPL, SEVERE, 54, Unexpected state, DbDirHandler, doWork, nicht ausfuehrbar
ASCII manager errors
Re: ASCII manager errors
maybe you have imported some internal datapoints.
At the internal datapoints the information is stored that an alert fileset shall be removed and therefore the system tries to remove the fileset.
Please check which data you have imported and if it is necessary to import all the information.
If some information is not needed you can remove it from the file before doing the import or use filter settings at the ASCII export to get only required information written to the ASCII file.
- akim
When I attempt to delete information from system DP I get messages:
WCCILevent (0), 2016.10.15 09:50:38.878, SYS, WARNING, 96, No authorization, EvManager, doReceive, Datenpunkttyp darf nicht manipuliert werden!
WCCOAascii_info:processing file D:\\WinCCproj\\ezbar_v1\\dplist\\all.dpl
WCCOAascii_info:deleted elements:
WCCOAascii_info:_Event.msg
WCCOAascii_info:DpType (2930): Modify msg for type _Event sent.
WCCOAascii_info:Error in answer from Event Manager, corresponding ascii file entry before or in line 2930
WCCOAascii_log:WCCOAascii (0), 2016.10.15 09:50:38.780, SYS, INFO, 1, Manager Start, PROJ, ezbar_v1, V 3.12 - 3.12 platform Windows AMD64 linked at Nov 28 2013 15:01:31
WCCOAascii_log:WCCOAascii (0), 2016.10.15 09:50:38.781, SYS, INFO, 3, Trying to connect to, (SYS: 0 Data -num 0 CONN: 1) @ server:4897
WCCOAascii_log:WCCOAascii (0), 2016.10.15 09:50:38.785, SYS, INFO, 4, Connected to, (SYS: 0 Data -num 0 CONN: 1) @ server (127.0.0.1)
WCCOAascii_log:WCCOAascii (1), 2016.10.15 09:50:38.804, SYS, INFO, 6, Initialization by Data Manager finished
WCCOAascii_log:WCCOAascii (1), 2016.10.15 09:50:38.805, SYS, INFO, 3, Trying to connect to, (SYS: 1 Event -num 0 CONN: 1) @ server:4998
WCCOAascii_log:WCCOAascii (1), 2016.10.15 09:50:38.806, SYS, INFO, 4, Connected to, (SYS: 1 Event -num 0 CONN: 1) @ server (127.0.0.1)
WCCOAascii_log:WCCOAascii (1), 2016.10.15 09:50:38.819, SYS, INFO, 102, Waiting for user names/passwords
WCCOAascii_log:WCCOAascii (1), 2016.10.15 09:50:38.819, SYS, INFO, 103, User names/passwords initialized
WCCOAascii_log:WCCOAascii (1), 2016.10.15 09:50:38.883, SYS, WARNING, 96, No authorization,
WCCILdatabg (1), 2016.10.15 09:50:39.216, IMPL, SEVERE, 54, Unexpected state, AlertDirDb, removeDb, nicht ausfuehrbar *** Code : 16
WCCILdatabg (1), 2016.10.15 09:50:39.232, IMPL, SEVERE, 54, Unexpected state, DbDirHandler, doWork, nicht ausfuehrbar
You are not allowed to modify the _Event DPT, since it contains the licensing stuff.
- akim
Ok, and what is wrong now?
WCCILevent (0), 2016.10.15 17:05:19.382, PARAM,INFO, 0, , Terminate manager (SYS: 0 None -num 0 CONN: 1)
WCCILevent (0), 2016.10.15 17:05:19.386, IMPL, INFO, 195, Message SHUT_DOWN_MANAGER received - exiting ..., (SYS: 1 Event -num 0 CONN: 1)
WCCOAui (1), 2016.10.15 17:05:19.394, PARAM,WARNING, 16, Requested module does not exist or has wrong type, DP: EZBAR:_Ui_1.LayerOff.PanelName:_original.._value, Para_13_paraPanel
WCCOAui (1), 2016.10.15 17:05:19.408, PARAM,WARNING, 16, Requested module does not exist or has wrong type, DP: EZBAR:_Ui_1.ModuleOff.ModuleName:_original.._value, Para_1
WCCILpmon (1), 2016.10.15 17:05:19.488, SYS, INFO, 22/pmon, Got RESTART_ALL command from WCCILevent, restarting the project
Update:
These messages appear even in a completely new project.
WCCILevent (0), 2016.10.15 18:10:21.300, PARAM,INFO, 0, , Terminate manager (SYS: 0 None -num 0 CONN: 1)
WCCILevent (0), 2016.10.15 18:10:21.304, IMPL, INFO, 195, Message SHUT_DOWN_MANAGER received - exiting ..., (SYS: 1 Event -num 0 CONN: 1)
WCCOAui (1), 2016.10.15 18:10:21.309, PARAM,WARNING, 17, Requested panel does not exist, PanelArea::closePanel,
WCCOAui (1), 2016.10.15 18:10:21.321, PARAM,WARNING, 16, Requested module does not exist or has wrong type, DP: System1:_Ui_1.ModuleOff.ModuleName:_original.._value, ProgressBar
WCCILpmon (1), 2016.10.15 18:10:21.334, SYS, INFO, 22/pmon, Got RESTART_ALL command from WCCILevent, restarting the project
Update:
Without knowing what you're importing, I can't say for sure.
Just guessing that you import some internal datapoint values, like _Managers.Exit which in turn would stop a manager ...
Try to remove all internal DPs and their values from your ASCII import file - you should not need them.
- akim
I just created a new project and export the whole database, then I tried to import it again.
In some of my older projects this does not happen. So I do not understand what was going on. I use v 3.12.
As said, you should not import the internal DPs. I can't say what has changed.
in older projects the last value storage for the dp-element _Managers.Exit was not inactive. Therefore the last value which was set is stored in the database.
If the information is exported and imported again the _Manager.Exit dp-element will be set. Depending on the value which is set a WinCC OA manager will be restarted.
In your case the event manager will be restarted.
As Martin Koller has written please do not import the information for the _Managers.Exit dp-element to avoid the problem that the event manager is restarted.
