Hysteresis problem in masterDP
NFedorenko
Post by NFedorenko »
Hello to all!
Today I found one misterious problem with alert handling power config.
When I check hysteresis in masterDP, and then transfered this config to all DP, basic alert_hld parameters synchronise. Everything but hysteresys.
Can anyone try the same. Maybe I do something wrong...
Tried on 3.14 P005 and 3.13 P006.
Re: Hysteresis problem in masterDP
Which powerconfig are you using? Or did you create your own powerconfig for this?
v_tsolis@akatt.gr
Post by v_tsolis@akatt.gr »
Hello.
I have the same problem.
I am trying to write Hysteresis values to a datapoint that i created from a MasterDP and it doesn't work. The Power config that I used is “Alert handling 5 ranges” and I am changing “_alert_hdl..u_hyst_limit.” When I am testing with datapoint that is not generated from a MasterDP it works correctly.
NFedorenko
I've tried to do the same with ETM official trainer in Russia, and we faced the same problem.
Hysteresis doesn't work in powerconfigs.
mkerk
Post by mkerk »
Hysteresis is not implemented in the WinCC OA Standard alarmhandling-Powerconfigs.
If you want to use Hysteresis with MasterDP, than you have to create your own PowerConfig or extend an existing one and set the alarm handling attribute "_alert_hdl.._hyst_type", "_alert_hdl.._l_hyst_limit" and "_alert_hdl.._u_hyst_limit" in this config.
BR,
Mousser
v_tsolis@akatt.gr
Thank you
