Im am a little confused with xmlrpcClient() and related methods. Is it necessary to call a method on a XmlRpc server by doing:
xmlrpcClient();
xmlrpcConnectToServer();
xmlrpcCall();
xmlrpcCloseServer();
Each and every time you call a function on the server or do we just need to call xmlrpcClient(), xmlrpcConnectToServer() and xmlrpcCloseServer() once in a control session? I.E.:
xmlrpcClient();
xmlrpcCall();
xmlrpcCall();
xmlrpcCall();
The documentation is not really clear on this. Both versions seem to work but I would like to know what the best practise is.
I am writing a control library wrapper for a xml-rpc service.
Jan
XmlRpc client
Re: XmlRpc client
The best solution also depends on the server and other network components. They might disconnect idle connections, so it requires extra function calls (and/or the tcp keepalive option).
In my experience with web services it is best to establish a new connection when there is a longer period of time between the function calls.
- jcbaar
Re: XmlRpc client
Gertjan,
Thanks for the information. I'll open/close the connection on each method call to make sure.
One more question though. It will not be a problem to call xmlrpcClient() multiple times? I.E.
void libFunc1()
xmlrpcClient();
xmlrpcOpenConnection();
xmlrpCall();
xmlrpcCloseConnection();
void libFunc1()
xmlrpcClient();
xmlrpCall();
}- Gertjan van Schijndel
Re: XmlRpc client
It is no problem calling 'xmlrpcClient()' multiple times, but it is only required once.
With multiple concurrent connections you need to make sure that the connections use a different id.
By the way the xmlrpc control extension will call the function 'xmlrpcOnConnectionClose(string id)', when the connection has been closed.
- jcbaar
Re: XmlRpc client
Gert-Jan,
Thanks for the information!
With these tips I am now confident that I am doing things in the correct manner.
Jan
Jan
