How to read / modify / save the text of notepad in the .pnl
gyu
Post by gyu »
Using a WinccOA 3.12 on the project.
customer request functioality like notepad .
if click the button on the screen, popup.pnl will be opened with notepad text .
and
when click the save button on the popup.pnl, overwrite it into notepad text.
plz tell me the solution with reference to attached file.
thanks. Image
m.sabitov
Re: How to read / modify / save the text of notepad in the .pnl
Post by m.sabitov »
Hi!
it's very easy, looking attach panel, but this simple example work only with one line text. https://www.winccoa.com/fileadmin/image ... tepad3.zip
notepad3.zip
(1.06 KiB) Downloaded 249 times
You can have a look at the CTRL function textEditor(), which opens a text editor which also allows to save the file again
(this solution does not use an extra panel).
You can also check the std panel: STD_PANELS/note_info (from the catalog). Either you can use it directly or just see how it's done there.
If you want your own panel, which contains a TEXT_EDIT widget, you can simply use
fopen(), fputs(), fclose() functions.
