Hello is there a way to disable XML-RPC multicall (system.multicall) in control manager?
used functions are:
(#uses "CtrlXmlRpc")
xmlrpcClient();
xmlrpcConnectToServer(id, host, port, secure);
xmlrpcCall(id, xmlRpcMethod, args, res);
xmlrpcCloseServer(id);
We have control manager that uses dpQueryConnectSingle(...)
This manager communicates with third party devices and software using XML-RPC.
In some cases XML-RPC multicall is generated form WinCCOA even each XML-RPC call is made in different thread.
Vedad
How to disable XML-RPC multicall
Re: How to disable XML-RPC multicall
can you please describe in detail what is meant with "multicall".
Does it mean that the function xmlrpcCall() is started several times (even if the first call was not finished)?
- e_hagenaar
Did you find a solution? because i have the same issue.
Erik-Jan
Vedad Ramovic wrote:
Erik-Jan
used functions are:
xmlrpcClient();
Vedad
- vedadramovic
Hello Erik-Jan,
yes.
When you call function xmlrpcConnectToServer() make sure to use different "id" as a parameter in every call. When you use the same "id" procedure thinks that it is meant for the same device, so it is making one connection with multiple XML-RPC calls.
Example.
string id = rand();
Vedad
yes.
Example.
string id = rand();
Vedad
- e_hagenaar
Hello Vedad,
Thank you very much! I used the getCurrentTime() but when the calls a made at more or less the same moment the id is the same and you get the multicall.....
Erik-Jan
Erik-Jan
Hello Erik-Jan,
yes.
Example.
string id = rand();
Vedad
- fmulder
Never(!) use rand() or getCurrentTime() as a unique id. rand() may eventually give the same number (although the chance is very small) and getCurrentTime() will give the same result when your application is too fast. Simply use a global integer that you increment every time.
share the fun
Frenk Mulder
global int g_iUnique = 0;
int iMyId = g_iUnique++;Frenk Mulder
