Hi
I get the next log "4/pmon, did not find the executable PVSStoolTunnel" when I connect the webclient with the server
does anyone know what this is
thanks
Webclient
- agruber
Re: Webclient
The tunnel tool is not used anymore since WinCC OA 3.12 (AFAIR). Which Version do you use? And how have you setup your webclient CTRL Manager?
BR,
BR,
- cofelyhoogland
Re: Webclient
Hi
I use version 3.10 SP2
on the server I run the following processes:
- Control manager with the options "WebClient_http.ctl -connectToRedundantHosts".
- OPC AE Server with the options "-connectToRedundantHosts".
from a web browser I try to start a Webpage.
I get the following message:
"4 / pmon did not find the executable PVSStoolTunnel"
- agruber
Re: Webclient
Eventually the executable PVSStoolTunnel is really missing. You can verify in the bin directory of your Installation.
If this is an existing old project, what did you change before it happened? Did you reinstall? Eventually you have not instaklled the http Server during setup.
If you do a new project, please use a new version like 3.14, as there are great enhancements like ULC UX.
BR,
BR,
- cofelyhoogland
Re: Webclient
Hi
Thanks, I copied the PVSStoolTunnel to the bin directory. and it seems to work.
I can call up a webpage now
thanks again
thanks again
