Hello
i have a problem with the dpCreate function in the UI Vision mode.
If i want to create a intern datapoint for the trend control in the type "_TrendConfig", i will get the following message in the log Viewer.
WCCILevent (0), 2016.09.08 15:45:44.023, SYS, WARNING, 96, No authorization, EvManager, doReceive, you are not allowed to create/modify the datapoint: System1:Test
If i try the Panel in the quick test mode it works.
I'm using WinCC OA 3.14 Update 3.
dpCreate Error No authorization, EvManager
Re: dpCreate Error No authorization, EvManager
maybe the UI running the Gedi and Quick Test is started with a different WinCC OA project user and therefore creating the datapoint is possible.
Please check which user is logged in running the UI with the Vision module.
- laual
It was a simply user problem sorry :laugh:
