WHERE clause using _DP _DPT etc for Oracle
jimtaylor
Post by jimtaylor »
Is there a different SQL syntax for "WHERE" clauses including _DP, _DPT, _EL etc in Oracle?
Example:
string query = "SELECT ALERT 'alert_hdl.._text' FROM '*' WHERE _DPT != \\"_DataManager\\" TIMERANGE(\\"2016.09.01 00:00:00\\",\\"2016.09.01 23:59:59\\",1,0)";
dyn_dyn_anytype result;
dpQuery(query, result);
This works fine when using HDB archive but not on Oracle (returns the inverse - i.e. just the data manager alarms).
Thanks,
Jim
p.s. I know in this is a horrifically inefficient query, but just using it as a simple example to focus on the syntax problem.
Re: WHERE clause using _DP _DPT etc for Oracle
are you queryRDBDirect = 1 when reading data for the Oracle database?
Have you tried if there is difference at the result when using queryRDBDirect = 0 and 1?
chris@blue-catalyst.co.uk
Post by chris@blue-catalyst.co.uk »
I have also come across problems with queries when using SELECT ALERT with TIMERANGE and ORACLE. I have tried Jim’s example above.
With queryRDBDirect = 0
_DPT = "_DataManager" returns all _DataManager alarms
_DPT != "_DataManager" returns all _DataManager alarms
_DPT LIKE "_Data*" returns nothing
_DPT NOT LIKE "_DataManager" returns nothing
With queryRDBDirect = 1 exactly the same results are returned, which aren't as anticipated.
Chris
