We have version 3.13 installed on our servers. We have installed v3.14 to prepare for the upgrade, however we still need 3.13 to run until we are ready to convert the project.
After installing v3.14, v3.13 has stopped working with the OPC Server.
It gives the following error in the log;
WCCOAopc (3), 2016.07.28 15:23:21.932, IMPL, WARNING, 54, Unexpected state, OPCServer, CheckSrvInterfaces, Server does not support IOPCBrowseAddressSpace -> no browse info (Class not registered (0x80040154))
WCCOAopc (3), 2016.07.28 15:23:21.932, IMPL, SEVERE, 54, Unexpected state, OPCServer, CheckSrvInterfaces, Server does not support IOPCServer -> server cannot be used (Class not registered (0x80040154))
It keeps repeating this over and over.
I've reinstalled v3.13, but no luck.
Any ideas?
OPC Server Stopped Working After Upgrade.
- lukedonovan
Re: OPC Server Stopped Working After Upgrade.
Did you also tried to reinstall the opc server?
- klotzm
i have the same problem....upgrade from 3.13 to 3.15 and the opc's are not working anymore.
The OPC Servers are OK, i have also tried to reinstall one of them...
WCCOAopc (1), 2017.05.08 14:16:16.544, IMPL, SEVERE, 54, Unexpected state, OPCServer, CheckSrvInterfaces, Server does not support IOPCServer -> server cannot be used (Klasse nicht registriert (0x80040154))
WCCOAopc (2), 2017.05.08 14:16:23.848, IMPL, WARNING, 54, Unexpected state, OPCServer, CheckSrvInterfaces, Server does not support IOPCBrowseAddressSpace -> no browse info (Klasse nicht registriert (0x80040154))
Has anyone already found a solution for the problem?!?
Martin
Martin
- lukedonovan
Hi Martin,
I uninstalled OPC Core Components (106.0) and reinstalled 105.0, and all worked fine.
Luke
Luke
- schneebergera
summary:
check installed software in Control Panel\\Programs\\Programs and Features
-- OPC Core Components Redistributable (x64) 106.0 (ver. >= 3.14)
-- OPC Core Components Redistributable (x64) 105.0 (ver. 3.12)
please have a look to ETM FAQ and follow the instructions:
https://portal.etm.at/index.php?option= ... &Itemid=54
regards,
summary:
regards,
